Kingdom of Heaven
    Kingdom of Heaven
    I have 2 desktops w/ DVDFab blu-copy. Both PCs can not open the source. The little blue rectangular box has had 10 minutes on both PCs and all that happens is the the disk open window keeps loading bar. Neither PC can open this old movie. HELP !!!!!
    Hi MERX2006
    Open Fab Click the Green top right > Protection > Path Player click Disable Path Player click OK restart Fab and try again, just remember to set it back to Always Enabled.
    Also try resetting DMA
    Open Fab Click the Green top right > General > make sure Check for DMA Automatically is Checked and also Click the Reset DMA to the right click OK and restart Fab.
    CBR929
      Also check the disk for scratches/marks/cleanliness. Clean & polish it.
        I followed instructions. ( No Improvement ) What should I do?
          Try another disk title and report results please.
            Hi MERX2006
            As stated by GregiBoy does this happen on other disc's????
            You may also try an older version of Fab if you have one, if not you can find older versions of Fab in the link in my signature.
            I would pick version 8073.
            If still having problems please post your logs the default location is:
            Please use attachment button and attach your most recent, Internal and Burn log(s) and post right here.
            CBR929
              I returned to 8.0.5.0, now everything is working again. I wonder if the downloads forward were faulty ( by my wrong doing ) or what?
