Not able to update or reinstall DVDfab
    Error I get.
    internal error: Failed to expand shell folder constant "userappdata"
    I uninstalled the program and cleaned out all the folders I could find but when I try to install the latest version I get the error above.
    I ran as Administrator, no luck.
    I did this and it still will not install:
    Please follow these steps to change your registry settings: (you should back up the registry before making any changes)
    Click on “Start-Run, type “regedit” (without the quotes)
    Navigate to this registry path:
    HKEY_CURRENT_USER --> Software --> Microsoft --> Windows --> Current Version --> Explorer --> User Shell Folders
    Clear the key: Recent (right mouse click on the key/folder, choose “Delete”)
    Close the Registry Editor and restart the computer.
    Then reinstall DVDFab
    Regards,
    mona
    Please help.
    thanks
    forgot to add this is on Win 7
    Hi Z_Ghost,
    It is not a program issue. Please google this error message "internal error: Failed to expand shell folder constant "userappdata"" , there are several methods to solve this problem.
    Sincerely,
    Sunny
      This warning is come from windows. We will check this later.
      Thanks,
      Potti
        I did and so far it's a no go. I guess I will just have to reload Win 7.
        DVDFab is the only program that is giving me a problem, I can install any other program without a problem.
        Thank you.
          Probably NTFS permissions error, try to set them for userappdata.
          人生は贈り物であり、完全な喜びを経験する必要があります
            will give that a try, thanks
              Well I got it fixed and wanted to add how I did it in the hopes that it helps the next person.
              I had to create a new admin user account, for me this is not a problem as I do not use my admin account for anything other then to add and remove programs and what little I do keep under that account I keep in 1 encrypted and password protected folder. So I was able to just delete that account after I created a new admin account and move my folder. I was then able to install DVDFab without any problem.
              Thanks for the help.
