Which do I get?
    Which do I get?
    I don't know which to download. I don't want to pay for something and turns out I got the wrong thing. I downloaded the trial version and now my trials are up. What is the difference from a passkey and the dvd copy? If I have the trial version do I just need the passkey for 40.00 or do I buy the dvd copy software for 50.00?
    You probably don't need Passkey as this will be a redundant decrypting tool as long as you have DVD Copy.
    DVD Copy will rip, compress and burn.
    Passkey is simply an "on-the-fly" decrypter and is used in conjunction with other software, such as Img, shrink, etc.
    It decrypts only.
      to the fairness and in addition to my friend's MaineMan words. I have to tell that DVDFab DVD Copy will only decrypt DVDs, and will compress/extract/modify content withing a frame of DVD container, while Passkey will decrypt both DVDs and BDs, but would not manipulate the content. I hope this helps
      sigpic
