Trying to enable Intel QuickSync tells me my CPU doesn't support it
    CPU/GPU Trying to enable Intel QuickSync tells me my CPU doesn't support it
    Hi everyone,
    I just got a new pc in the last few weeks with an i5 2500k cpu (Intel HD 3000 graphics). I do not have a seperate GPU as I wanted to use this so called improved integrated graphics and don't need a powerful dedicated card as I'm not a gamer.
    Yesterday I tried using DVDFab for the first time in a while and when I go into settings and try to enable "Intel QuickSync" I get an instant notification that says "Your CPU doesn't support this feature".
    HD3000 should most definitely support this.
    My DVDFab version is 8.1.1.2
    Win 7 Ultimate 64 bit
    Intel core i5 2500k
    New Asus mobo H67 chipset with IGP
    8gb ram
    I only use DVDFab for basic DVD rips and occasional conversion from one format to another, I don't have bluray etc..
    My system is, so far, 100% error free, everything is fully updated.
    Is this a problem with Fab or is it an Intel driver issue??
    Any replies would be very much appreciated as I would just love to be able to see if using 'sync' really is all that much faster/better.
    Thank you.
    Go to Intel's website and make sure you have the latest video driver;
    http://downloadcenter.intel.com/Sear...00&FamilyId=39
    Also, make sure it isn't disabled in the Bios.
    If you wanted to use a discrete GPU you would need Lucidlogix VIRTU.
      Thanks for your answer, yes there was an update/newer version of the Intel driver, did that and it is now enabled in the DVDFab settings.
      It works very well indeed, very fast dvd rip when selecting a single pass fast encode.
      I notice that when selecting a 2 pass high quality encode it goes back to using the slower software setting, is this right?, I ask because I figured that it would do 2 fast passes using the quick sync/gpu acceleration enabled ??
        I never use 2 pass, I would have thought it would still use QuickSync.
        Maybe the developer can enlighten us.
