copying to computer
    copying to computer
    I am new to dvd fab i have dvd to dvd can i copy straight to my computer instead of making a backup copy and then trying to figure out how to get it on my computer. Any help would be nice
    Change you Target from your burner to a hard drive.
    See attachment.
      I changed my target which worked but it copied the movie and it came out in two parts Audio TS & Video Ts how can i get it to normal ?
        Audio TS folder is empty and unused.
          Yes it is empty but required by DVD specs...
            Ok maybe I missed something? The OP implied the movie would be played from the HDD and I was just saying he need not be concerned about it. Delete it if you want to, when burned to a blank with a burning engine it will be there on the backup. It’s an automatic relic.
              I have struck SOME software and hardwate players that require it there to play. It seems that if it is not there, they do not recognise the folder as a DVD structure.
                Hi aksword
                If you have problems playing the file on your computer try these free players MPC found here http://mpc-hc.sourceforge.net/downlo...lassic-hc.html or VLC found here http://www.videolan.org/vlc/
                CBR929
                  Originally posted by brownsmith
                  Hello all,
                  i have same problem please tell me in detail..
                  Helpppppppp.
                  Smith Brown
                  You have been told in detail in the preceding posts.
                  Read them.
                    This is the Normal DVD File Format. Another option is to click on the "disc" icon next to the target location (instead of the "Folder" Icon), then it will be be stored as an "ISO" file instead of the folders.
                    Many Media Players can play the ISO file directly or you can Mount it using Virtual Drive then it will look like a DVD.
