ATI Radeon HD4850
    ATI Radeon HD4850
    Should I continue to use software decoding or are there better options available with my graphics card?
    Packard Bell
    Intel 8300 2.5gb Quad core
    4gb ram
    ATI HD4850 1gb
    Windows 7 Home Premium 64bit
    Liteon iHOS104 Bluray drive (read only)
    Norton 360 antivirus & firewall
    Hi seanamos
    If you had a good card that supported Cuda I would say you could use that to help in the process, so you are better off using Software options.
    CBR929
      Your card is a solid card. You can enable ATi Stream if you like. Sadly, it is not nearly as optimized as CUDA is so you won't see nearly the boost in performance. But there will be some. You will need the latest drivers AND the latest AMD Media Codec Package. The 2 HAVE to match version numbers in order to get the media package to work.
