Can't copy movie
    Can't copy movie
    I can't copy the movie "The Smurfs." Everytime I try to copy it, it says "Error while reading." Here's what I'm getting.
    2011-12-03 16:29:45 ---- ******************** Log session stop 03-Dec 16:29:45.668 PID 7028********************
    2011-12-03 16:27:55 Info Current Drive selected : 0:1:0 - hp DVD A DH16ABLH 3HD9 [E] (Ide)
    2011-12-03 16:27:55 Info Using Advanced SPTI interface
    2011-12-03 16:27:55 Info System default language : English (United States)
    2011-12-03 16:27:55 Info User default language : English (United States)
    2011-12-03 16:27:55 Info DLL Version : 4.0.20.488
    2011-12-03 16:27:55 Info DLL : C:\Program Files (x86)\DVDFab 8 Qt\vso_hwe.dll
    2011-12-03 16:27:55 Info Version : 8, 1, 3, 6
    2011-12-03 16:27:55 Info ExeName : C:\Program Files (x86)\DVDFab 8 Qt\DVDFab.exe
    2011-12-03 16:27:55 Info OS : Microsoft Windows 7 Home Premium (Build 7601: Service Pack 1)
    2011-12-03 16:27:55 ---- ******************** Log session start 03-Dec 16:27:55.524 PID 7028********************
    Analyzing of DVD started: 16:28:57
    Task_1 failed! Error=102(): 16:29:37
    smurfs
    there is new copy protection on this movie, will be supported soon
      What...
      I just used DVD Fab for a Blu Ray copy and i had no problem. Make sure the DVD is clean and that your DVD Burner is also clean. You have to buy a DVD cleaner disk for your burner. I have had problems with a bad DVD movie. I had to go get another copy and it worked.
        The smurfs
        Did that did not copy either......
