Everything worked fine until about halfway thru the burn process. Whole bunch of pop-up windows that I don't understand. Here's the burn log & I'd appreciate some guidance cause I don't want to make another coaster!
I 15:28:56 ImgBurn Version 2.5.6.0 started!
I 15:28:56 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7601 : Service Pack 1)
I 15:28:56 Total Physical Memory: 3,931,448 KB - Available: 2,427,928 KB
I 15:28:56 Initialising SPTI...
I 15:28:56 Searching for SCSI / ATAPI devices...
I 15:28:57 -> Drive 1 - Info: hp DVD-RAM GH40L RB0E (E
(ATA)
I 15:28:57 Found 1 DVD±RW/RAM!
I 15:28:57 Operation Started!
I 15:28:57 Building Image Tree...
I 15:28:58 Checking Directory Depth...
I 15:28:58 Calculating Totals...
I 15:28:58 Preparing Image...
I 15:28:58 Checking Path Length...
I 15:28:58 Contents: 14 Files, 2 Folders
I 15:28:58 Content Type: DVD Video
I 15:28:58 Data Type: MODE1/2048
I 15:28:58 File System(s): ISO9660, UDF (1.02)
I 15:28:58 Volume Label: DS9S6D3
I 15:28:58 IFO/BUP 32K Padding: Enabled
I 15:28:58 Region Code: 1, 2, 3, 4, 5, 6, 7, 8
I 15:28:58 TV System: NTSC
I 15:28:58 Size: 4,509,081,600 bytes
I 15:28:58 Sectors: 2,201,700
I 15:28:58 Image Size: 4,509,696,000 bytes
I 15:28:58 Image Sectors: 2,202,000
I 15:28:58 Operation Successfully Completed! - Duration: 00:00:00
I 15:28:58 Operation Started!
I 15:28:58 Source File: -==/\/[BUILD IMAGE]\/\==-
I 15:28:58 Source File Sectors: 2,202,000 (MODE1/2048)
I 15:28:58 Source File Size: 4,509,696,000 bytes
I 15:28:58 Source File Volume Identifier: DS9S6D3
I 15:28:58 Source File Volume Set Identifier: 3F9D7B9C0021998B
I 15:28:58 Source File Application Identifier: IMGBURN V2.5.6.0 - THE ULTIMATE IMAGE BURNER!
I 15:28:58 Source File Implementation Identifier: ImgBurn
I 15:28:58 Source File File System(s): ISO9660, UDF (1.02)
I 15:28:58 Destination Device: [0:1:0] hp DVD-RAM GH40L RB0E (E
(ATA)
I 15:28:58 Destination Media Type: DVD+R (Disc ID: MCC-004-00)
I 15:28:58 Destination Media Supported Write Speeds: 4x, 8x, 12x, 16x
I 15:28:58 Destination Media Sectors: 2,295,104
I 15:28:58 Write Mode: DVD
I 15:28:58 Write Type: DAO
I 15:28:58 Write Speed: 8x
I 15:28:58 DVD+R Reserve Track: No
I 15:28:58 Link Size: Auto
I 15:28:58 Lock Volume: Yes
I 15:28:58 Test Mode: No
I 15:28:58 OPC: No
I 15:28:58 BURN-Proof: Enabled
I 15:28:58 Write Speed Successfully Set! - Effective: 11,080 KB/s (8x)
I 15:28:58 Filling Buffer... (40 MB)
I 15:29:00 Writing LeadIn...
I 15:29:21 Writing Session 1 of 1... (1 Track, LBA: 0 - 2201999)
I 15:29:21 Writing Track 1 of 1... (MODE1/2048, LBA: 0 - 2201999)
W 15:34:00 Failed to Write Sectors 1417920 - 1417951 - Reason: Unknown (Internal Target Failure) (ASC: 0x44, ASCQ: 0x86)
W 15:34:00 Retrying (1 of 20)...
W 15:34:00 Retry Failed - Reason: Invalid Address For Write
W 15:34:00 Retrying (2 of 20)...
W 15:34:00 Retrying (3 of 20)...
W 15:34:00 Retrying (4 of 20)...
W 15:34:00 Retrying (5 of 20)...
W 15:34:00 Retrying (6 of 20)...
W 15:34:00 Retrying (7 of 20)...
W 15:34:00 Retrying (8 of 20)...
W 15:34:00 Retrying (9 of 20)...
W 15:34:00 Retrying (10 of 20)...
W 15:34:00 Retrying (11 of 20)...
W 15:34:00 Retrying (12 of 20)...
W 15:34:00 Retrying (13 of 20)...
W 15:34:00 Retrying (14 of 20)...
W 15:34:00 Retrying (15 of 20)...
W 15:34:00 Retrying (16 of 20)...
W 15:34:00 Retrying (17 of 20)...
W 15:34:00 Retrying (18 of 20)...
W 15:34:00 Retrying (19 of 20)...
W 15:34:00 Retrying (20 of 20)...
W 15:34:01 Retry Failed - Reason: Invalid Address For Write
W 15:35:10 Retrying (21)...
W 15:35:10 Retry Failed - Reason: Invalid Address For Write
W 15:35:12 Retrying (22)...
W 15:35:12 Retry Failed - Reason: Invalid Address For Write
E 15:35:14 Failed to Write Sectors 1417920 - 1417951 - Reason: Unknown (Internal Target Failure) (ASC: 0x44, ASCQ: 0x86)
E 15:35:14 Next Writable Address: 1417376
I 15:35:14 Synchronising Cache...
I 15:35:23 Closing Track...
I 15:35:24 Finalising Disc...
W 15:35:48 Potential 'WaitImmediateIO' Deferred Error - (51%, 0/3) - Unknown (Internal Target Failure) (ASC: 0x44, ASCQ: 0x86)
W 15:35:48 Finalise Disc Failed! - Reason: Unknown (Internal Target Failure) (ASC: 0x44, ASCQ: 0x86)
W 15:35:55 Finalise Disc Failed! - Reason: Unknown (Internal Target Failure) (ASC: 0x44, ASCQ: 0x86)
E 15:35:55 Failed to Write Image!
I 15:36:01 Exporting Graph Data...
I 15:36:01 Graph Data File: C:\Users\Jon\AppData\Roaming\ImgBurn\Graph Data Files\hp_DVD-RAM_GH40L_RB0E_THURSDAY-DECEMBER-29-2011_3-28_PM_MCC-004-00_8x.ibg
I 15:36:01 Export Successfully Completed!
E 15:36:01 Operation Failed! - Duration: 00:06:56
I 15:36:01 Average Write Rate: 8,033 KB/s (5.8x) - Maximum Write Rate: 11,133 KB/s (8.0x)
I 15:36:23 Close Request Acknowledged
I 15:36:23 Closing Down...
I 15:36:23 Shutting down SPTI...
I 15:36:23 ImgBurn closed!
I 15:28:58 OPC: No
