AVI Tag Editor
    Other AVI Tag Editor
    I have a few movies that I do not want to go back and re-rip but the titles are messed up. Now I have used a few tag editors but it cuts the movie. Can someone point in the direction of a good tag editor.
    FBS
    I generally use ABC AVI Tag Editor.
      I tried that and it Tourniquets the file and I lose like 15 mins and the end becomes unplayable. Maybe I am doing something wrong????
        It insists that an AVI file should be under 2gb.
          The file is like 1.39 GB so it is far under the size of 2GB. Color me stupid!? I can find the place to edit the tag, and I take out the underscores. I arrange the name the way I like it, and the rating of the movie.
          As you can see it is below the 2gb mark
          Underscores are a bit "ugly" when I load in MediaCenter.
          Here I have fixed all of the areas that I would like fixed.
          And when I go to save I get this and then it makes the file about 1gb in size... Did I miss a step somewhere?
          FBS
            Nope. What profile did you use to create them?
              Profile: generic.avi.xvid.audiocopy
              FBS
