Hello - Has anyone had this problem/can you offer any solutions? All of the movies I’ll been coping has been from single layered disc. After DVDFAB finish copying the movie and move on to the writing phase I keep getting this massage “Media inserted in drive is a single layer. Please insert a double layer media to start the write process”. I’m new to this whole coping process and I’m not sure how to fix it. Does anyone have any suggestions?
Please Help
Hi Lucelips and welcome,
Hopefully, it's simply a matter of selecting the correct settings.
On the opening Fab screen, near the bottom, please be certain you have selected DVD5 and Not DVD9 as the target size..
To the right of this you'll see Quality _ % and then two file sizes.
These numbers represents the amount of compression applied and the original and resultant (ripped) file sizes.
Also navigate into Common Settings > DVD to DVD and select DVD5 as the default size.
Recommend that you spend some time on the tutorial.
Just click on the ? mark icon upper tight and select Tutorial on the dropdown
I'm Moving your thread to General QuestionsLast edited by maineman; 12-10-2009, 07:33 PM.If it ain't broke, don't fix it!
