Imgburn
    Other Imgburn
    Can you direct me to the download location for ImgBurn, and info to install to work with DVD FAB. Thank you.
    This link is in CBR929's (Super Moderator) signature
      Roger that
        ImgBurn
        I have DL and installed ImgBurn using the video turorial which reflects the start page in v8, for applying the settings. I could not locate any instructions or settings in v9. I do my ripping mainly in v9, and I do not seem to have ImgBurn syncronized with DVDFAB v8 or v9, and currently using it manually. Could use so more explicit instructions, now that v9 will prevail.
          Hi jetman4615
          Click the settings icon in version 9, looks like a cog wheel.
          Click drives> DVD Write>Burn Engine here you can choose your burn engine.
          Hope this helps
          CBR929
            ImgBurn
            Thanks CBR929,
            I applied the settings, although I have not tested yet, as I have two more setting issues that need attention, if I may.
            Does v8 automatically receive the settings, or do I have to go to v8, also.
            I have a few backups that were accomplished in v9. When I insert the disk in a player, the movies starts at an advanced mode of 6-16 minutes, instead of the beginning of the disk. I was trying out the "change dvd playback" and not sure if I have it set correctly. Right now the "jump to fist menu when disk is inserted" is selected.. I cannot remember if that button was highlighted before I started messing with it two days ago. I realize the industry maneuvers the menus to create protection. Is there a rule of thumb setting for this problem?
            Thanks again.
