Another Disheartening 8225 v. 9017 Review
    Finally, I was able to do a side by side comparison review of these 2 versions on the same Bluray: RIO-a Blue Sky Cartoon.
    Here are the results that have more than disturbed me by the gross inferiority of Version 9 as follows:
    Version 8225: Faster loading.
    Easier to select the desired audio channel.
    16 minutes only to finish the whole process.
    Smaller file-24.3G in a single file (800).
    Has Chapter access.
    Version 9117: Seemed taking forever to load.
    Must use Custom to select only one HD audio.
    27 minutes to finish the process.
    Much bigger file-36.4G, 10G more, in multiple files.
    Even worse, NO CHAPTER ACCESS.
    To any normal human being, 9 is not a progress by any standard. It is a crime (sorry for being sarcastic).
    I then did another test of 9117, using the default Main feature and I ended up with a result of 24.6G (still 300 mb more) with 2 audio channels (HD and another channel with director's remarks that I don't need). It took 18 minutes and has chapter access.
    In short, the developers must be mindful of such gross deficiencies of Version 9, among others as noted before by many other members, e.g., no PCM for ripping), before de-commissioning the well tested and well loved Version 8.
    I suspect that Version 8 must have taken over a decade to perfect. Please do not trash such a well tested and loved version before the 9 is equal to or better than the 8.
    Otherwise, many may feel hijacked against our will.
    Another sad news for 9017.
    This 9017 crashed Car2 (bluray) twice after forever loading, but before opening the folder. The 8226 finished the same Cars2 within 16 minutes without any hassle. BOTH LOGS ARE COPIED BELOW FOR THE TEAM TO STUDY FOR CORRECTION AND IMPROVEMENT. THANKS,
    DVDFab 9.0.1.7 (2012/12/25 15:24:03)
    0m 00.20s: GPUAccelerate: 3
    0m 00.21s: CUDA cap: 0
    0m 00.21s: Support coreavc decode: 0
    0m 00.21s: Graphics info: ATI Radeon HD 4650 : :
    0m 00.21s: Qt Translator file load success
    0m 00.24s: Start get sys number.
    0m 00.24s: Serial number is: 78-e3-b5-a9-f4-e0
    0m 00.24s: Reg URL link is:
    0m 00.24s: Version is: 9017
    0m 00.24s: Product is: 2
    0m 00.24s: Connect type is: 0
    0m 03.63s: Times of connecting error is: 0
    0m 03.63s: Parse string is: 2:8260762964
    0m 03.63s: Parse string is: 20:8260762964
    0m 03.64s: Parse string is: 11:8260762964
    0m 03.64s: Parse string is: 50:8260762964
    0m 03.64s: Parse string is: 80:8260762964
    0m 03.64s: Parse string is: 21:8260762964
    0m 03.65s: Parse string is: 22:8260762964
    0m 03.65s: Parse string is: 60:8260762964
    0m 03.65s: Parse string is: 70:8260762964
    0m 03.65s: Parse string is: 61:8260762964
    0m 03.65s: Parse string is: 62:8260762964
    0m 03.65s: Parse string is: OV:9017
    0m 03.65s: Parse string is: BV:
    0m 03.65s: Parse string is: S:e2b2f6502c6ebb5a3133126aeadb37f6
    0m 03.75s: End check info.
    0m 03.75s: Load config successful.
    0m 03.93s: Init profile data driver sucessful.
    0m 03.94s: Init GPU settings sucessful.
    0m 03.94s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
    0m 03.94s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
    0m 09.99s: Init burn engine successful.
    0m 10.21s: opening drive F
    0m 10.21s: opened i/o
    0m 10.22s: got media type 15
    0m 11.63s: got max lba 22796767
    0m 12.90s: got disc type 20
    0m 12.90s: type Blu-ray BDMV
    0m 12.91s: volume label CARS2_D1
    0m 12.93s: opening drive G
    0m 12.94s: opened i/o
    0m 12.94s: failed to detect media type: sensekey 00 asc 00 acsq 00
    0m 12.94s: got max lba 0
    0m 12.98s: internal path F:/BDMV/
    0m 14.24s: aacs 1 bd+ 0
    0m 17.11s: Java protection is removed by StealthyClone anti-protection.
    0m 17.26s: got discinfo
    0m 17.47s: got bdmv
    0m 17.48s: Vendor: ATAPI
    0m 17.48s: Product: iHBS112 2
    0m 17.48s: Revision: CL0K
    0m 17.49s: Vendor specific: 2011/02/08 11:11
    0m 17.49s: AACS version: 1
    0m 17.49s: Number of concurrent AGIDs: 2
    0m 17.49s: Supports bus encryption: NO
    0m 17.49s: Supports binding nonce generation: NO
    0m 17.49s: Supports Hybrid discs: NO
    0m 17.49s: got agid 0
    0m 17.55s: sent host cert chal
    0m 17.56s: got drive cert chal
    0m 17.56s: BEC 0
    0m 17.56s: DRIVE_VENDOR 0x0128
    0m 17.63s: got drive key
    0m 17.64s: got host key signature
    0m 17.64s: verified drive signature
    0m 17.64s: verified host signature
    0m 17.72s: sent host signature and key point
    0m 17.72s: got bus key
    0m 17.73s: got agid 0
    0m 17.79s: sent host cert chal
    0m 17.80s: got drive cert chal
    0m 17.80s: BEC 0
    0m 17.80s: DRIVE_VENDOR 0x0128
    0m 17.87s: got drive key
    0m 17.87s: got host key signature
    0m 17.87s: verified drive signature
    0m 17.88s: verified host signature
    0m 17.95s: sent host signature and key point
    0m 17.96s: got bus key
    0m 19.97s: got volume id
    0m 19.98s: got volume id mac
    0m 19.98s: volume id is correct
    0m 19.98s: got vid
    0m 20.15s: blu-ray BD3620A68F82F5F26D18D13A7C29AB9468C0FE6F
    0m 20.80s: cert BEE=0x00 same
    0m 22.34s: D C0455755
    0m 22.35s: got vuk
    0m 22.72s: got unit key 1
    1m 42.74s: got extended bdinfo
    1m 42.75s: opened blu-ray
    1m 43.94s: terminate process
      Has Chapter access.
      Version 9 will be fine it is still a work in progress instead of getting upset about improvements being made in each new release of version 9 they are still updating version 8 for all dvdfab users to use.
      I don't see the problem at all the company could of discontinued version 8 all together but they did not instead we have two versions use version 8 and stop bashing a company that is working its A$$ off to get version 9 to where it needs to be.
        Thank you for your caring concerns.
        I am sure that the Team will "eventually " get 9 right. My impression was that the Developer was ready to discontinue the 8 soon, given the haste they upgraded a beta 9 that was still plagued with material bugs to an official release.
        As long as the 8 remains until the 9 is perfected to a comparable stability, I am happy. Nevertheless, I still feel compelled to advise the Team of the bugs that I have encountered for common benefits. Accordingly, the sarcasm is removed to reassure my hope and support for the Team.
          Nice to see you compared the two versions though and I am sure it will benefit not only Dvdfab but also all of it's users.
            Hi childer:
            We will check you post problems ASAP.
              dvd fab9
              i for one hope that fab 8 stays around for i CAN NOT for the life of me get verson 9 to run at all. it just sets ther and does NOTHING. i have a home built pc with win 2000 pro. that verson 8 works great with and win xp that will
              run verson 8 but REFUSES to run the so called beloved verson 9. i have tried every update of 9 with the SAME response NOTHING. So if they drop verson 8 I'm screwed and tatooed as they say.
                Hi, Team Leader,
                Thanks, and Happy Holidays,
