dvd ripper no sound
    dvd ripper no sound
    Video is ok, but there is no audio. Using dvdFab version 8.2.2.6 on Windows 7 64-bit. It does Men in Black 3 in MPEG2 format. Other software does not have that problem. Why should I spend $75.00 (or whatever it was) for something that I can't use? I want my money back!
    Rubbish.
    Fab works so you must be doing something wrong. If you want help, ask for it.
    Also, you had a 30 day free trial to iron out any procedural problems so don't come crying here..
      Originally posted by GregiBoy View Post
      Rubbish.
      Well, I didn't post for my health Why doesn't it work? I've tried changing the format type but when I do it erases everything from the Source box, acting as if the dvd drive is empty. The Blue-Ray ripper works as expected, just can't get dvd ripper to work right.
        Hi AncientDragon
        Please post your internal log.
        CBR929
          This is the last one I just tried. The name of this DVD is The Ten Commandments (new version)
          DVDFab 8.2.2.6 (2013/01/20 20:01:53)
          0m 01.36s: GPUAccelerate: 12351
          0m 01.36s: CUDA cap: 1
          0m 01.37s: Support coreavc decode: 0
          0m 01.37s: Graphics info: NVIDIA GeForce GTX 550 Ti : 5.0 : 2.1
          0m 01.37s: Qt Translator file load success
          0m 01.41s: Load config successful.
          0m 01.51s: Init profile data driver sucessful.
          0m 03.87s: Init GPU settings sucessful.
          0m 03.87s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
          0m 03.87s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
          0m 04.13s: Config ExBar successful.
          0m 04.13s: dvd2dvd have 8 elements.
          0m 04.28s: dvd2mobile have 31 elements.
          0m 05.18s: blu-ray2blu-ray have 4 elements.
          0m 05.21s: blu-ray2mobile have 20 elements.
          0m 05.79s: blu-ray23d have 7 elements.
          0m 05.96s: blu-ray2dvd have 1 elements.
          0m 06.00s: file2mobile have 30 elements.
          0m 06.89s: file2dvd have 1 elements.
          0m 06.91s: file2bluray have 1 elements.
          0m 07.29s: Config work ui controls successful.
          0m 07.35s: Init burn engine successful.
          0m 07.40s: StartNotify successful.
          0m 07.41s: opening drive D
          0m 07.41s: opened i/o
          0m 07.41s: got media type 4
          0m 07.60s: got max lba 4113343
          0m 07.61s: got disc type 10
          0m 07.67s: type DVD-VIDEO
          0m 07.67s: volume label 10_COMMANDMENTS
          0m 08.01s: internal path D:/VIDEO_TS/
          0m 08.03s: got copyright 1 fe
          0m 08.48s: got udf/iso
          0m 09.94s: got discinfo
          0m 09.95s: pathplayer enabled
          0m 13.24s: button: vts_4 menu_1 pgc_6 cell_2 sector_5090 count_4
          0m 22.72s: button: vts_4 menu_1 pgc_7 cell_1 sector_20631 count_4
          0m 22.98s: button: vts_4 menu_1 pgc_9 cell_2 sector_52015 count_11
          0m 23.09s: button: vts_4 menu_1 pgc_13 cell_1 sector_74197 count_11
          0m 23.18s: button: vts_4 menu_1 pgc_14 cell_1 sector_83031 count_11
          0m 23.28s: button: vts_4 menu_1 pgc_15 cell_1 sector_91872 count_11
          0m 23.37s: button: vts_4 menu_1 pgc_16 cell_1 sector_100669 count_11
          0m 23.45s: button: vts_4 menu_1 pgc_17 cell_1 sector_109470 count_11
          0m 23.74s: button: vts_4 menu_1 pgc_12 cell_1 sector_65368 count_11
          0m 24.65s: button: vts_4 menu_1 pgc_8 cell_2 sector_37701 count_4
          0m 26.82s: got dvdinfo
          0m 26.82s: opened dvd
          0m 32.78s: WorkAttr::Init Start
          0m 32.84s: WorkAttr::Init OK: generic.mp4.h264.mp3
          1m 16.91s:
          1m 16.91s: info: create config(0)
          1m 16.91s: info: convert profile(generic.mp4.h264.mp3)
          1m 16.91s: info: dvd playlist(2),angle(0),chapter(1->15),3D(0)
          1m 16.91s: info: streams((480.2)(128.2))
          1m 17.60s: info: set output video frame_rate(30000/1001)
          1m 18.91s: info: h264_encode: encode param profile(1) level(30) bitrate(1308)
          15m 55.26s: audio_encode finish job
          16m 20.39s:
          ------ finish mobile work ------
            Help would be greatly appreciated.
              The mp3 audio you've selected is not widely supported natively. You might try an AAC stream or find the mp3 codec for your playback device. mp3 audio will not play in iTunes or Windows Media Player natively.
                I have both Xbox 360 and PS3 devices. Other software uses AC3 format, which works ok with my devices. The only option available on DVDFab is MPEG2, which has no sound. How do I get DVDFab to use the same or similar format as Other software? (BTW: You might have guessed I know next to nothing about video formats.)
                  Try the mp4.h264.ac3 profile if your devices play ac3 audio.
                    BTW the last update bricked my PS3 so be advised!
                      Hi AncientDragon
                      I have edited 2 of your posts, please do not mention other software by name this is a DVD Fab forum.
                      Thanks
                      CBR929
                        best thing that could ever happen to it!!
                          The last piece of Sony crap in my house and it will not be replaced!
                            Hi AncientDragon
                            Thanks
                            CBR929
                            The reason I mentioned it was because theirs works and your doesn't. But I guess you can't stand the competition
                              Competition is a fine thing, but this forum is provided by DVDFab to discuss their software. Check the attitude or your stay with us will be a short one.
