DVDFabv9023
    DVDFabv9023
    Unable to download DVD Fab version 9023. I am advised "unable to execute file Create process failed. Code 740 Requires elevation". I was able to return to version 9022 which works fine. Any thoughts.
    Hey Jak
    How are you downloading the installer, running the installer or saving it.
    If running it, try saving it to a download folder then right click on it and run as administrator.
    Hope this helps
    CBR929
      DVDfabV9 v9023
      Many thanks CBR929, You are indeed a SUPER Moderator. Following your instructions problem solved. Funny, never had this problem before, running latest versions. It's good to know that the Super Moderator is there to keep me on the straight and narrow with his expertise.
