Upgrade Instal/Uninstal Problems
    I hope some can help me as I have spent almost 24 hours on this and I am groing weary !!!
    I am a reg owner of DVDFab Gold, and using the program for serveral years with virtually no problems. When a new ver. is made available, I upgrade to the new ver without any problems until this past week. Here is the senerio:
    1. I am using Operating System Windows 7 Pro
    2. Tried to install 8.2.2.6.
    3 Downaload no problem
    4. Install seemed to go OK until the last screen of finish of install and the computer just froze up. Green bar had not action and I couldn't even cancel.
    In the past new versions loaded easily, and fast.
    5. New directory was created, and many files loaded.
    6. Couldnt't unistall, and had to go to SAFE MODE to remove (unistall)
    This just dosen't make sense to me, as I have never had any problems instal new versions.
    End results I was able to install ver 8.0.8.5 wish is very old version of DVDFAB8.
    Thank goodness for saving the older versions of this program.
    I even tried to upgrade this version to the next, and it just won't work.
    Can someone please give me some guidance, and help me. I really hate to give up on this program, as it has served me well all these years. It is a Great program.
    Thank you in advance to any assitance to anyone, that has the time to help out this "old guy"
    Putting your email address in a post is a really bad idea, spammers love that. I'll remove it for you and you can exchange addresses via PM - much safer!
      Thank you sir.
      Paul
        Hi pmartasian
        Please try uninstalling DVD Fab through its uninstaller.
        Next download CCleaner from here run the cleaner option, clicking the old prefetch data in advanced options, then run the registry until nothing is found.
        Now download a fresh installer from here instead of clicking "run" click "save" now navigate to your download folder right click on the installer click run as administrator and reinstall Fab.
        Hope this helps
        CBR929
          Thank you for taking the time to respond to my install problem. I followed your instructions to the "T" but didn't have any success. I am really frustrated as I have been using this program for several years, and been 100% happy. Now the only version I can use is a 2 year old version. I have updated and updated over the years. I think my reg version goes way back when it was called DVD Fab Gold.
          Thank you again my friend for your attempt to help me.
          Paul
          Sacramento, Ca
            Hi pmartasian
            Have you checked to see if your anti virus or firewall is stopping the install?
            What do you use for an anti virus program?
            How about trying version 9 found here
            Hope this helps
            CBR929
              I am at my wits end !!!! All of the suggestions you have sent me make good sense. But unfortunately have not fixed my issues.
              I guess will have leave it to the tech support guys. Unless of course you have another thoughts.
              Thank you again for your time to help this "oldtimer." You have been very kind......
              Frustrated,
              Paul
                Honestly Paul, you will be better to try to get it resolved thru this forum as with support there will be delays.
                What operating system are you using?
                  Hey GregiBoy
                    Too busy getting ready to watch Super Bowl & missed that.
                    49ers or Ravens?
                    Sorry...
                      49ers or Ravens?
                      Sorry...
                      Ravens
                        Yes, I am using Windows 7 Pro
                          Hi pmartasian
                          Do you have a video card and is it running the most recent drivers?
                          Also what kind of anti virus do you run?
                          CBR929
                            I anm running Norton Antivirus. Why would the video card drivers cause a problem with the install of the program? However I will check to make sure.
                            I am desperate, and will do whatever you suggest my friend.
                            Phm
