Are there any "Insert Disc 2" and "Insert Disc 1" screens available without the DVDFab monkey that we can use?
Are there any "Insert Disc 2/Disc 1" screens without the DVDFab monkey?
You can use the "black screen", which is essentially no screen. Just select it in Common Settings.
I remember with the old Gold application (which was part of Platinum in the thrilling days of yesteryear) you had the option to plug in pretty much any screen you wanted... this Change Graphic Picture (CGP) was a user option back then.
I don't know if you can still do this easily. You might try google and see what's out there.
Sorry, I can't be of more helpLast edited by maineman; 12-18-2009, 01:00 AM. Reason: So old , I can't put 3 letters in the right orderIf it ain't broke, don't fix it!
The CGP files are held under the Program Files\DVDFab6\CGP and there is one for Black Screen and one for DVD Fab.
I suspect these are a graphic format but I copied one and renamed it BMP, JPG & GIF but couldn't open any of them.
Maybe someone else knows what format these are in."Beer is living proof that God loves us and wants us to be happy."
- Benjamin Franklin 1706-1790
Yes, I knew about the Black Screen choice there to select, rather than the Monkey King screen. I'm trying to find out if there are pre-made ones somewhere that we can browse through and pop in and how we would do that, the popping in part, I mean? Just put this CGP file in the CGP folder and it would appear automatically in the drop-down menu perhaps?Originally posted by maineman View PostYou can use the "black screen", which is essentially no screen. Just select it in Common Settings.
Hey! Cool! You found a Guide as to how to create CGP files from scratch! Neat! That Guide could come in handy some day.Originally posted by GregiBoy View PostThe CGP files are held under the Program Files\DVDFab6\CGP and there is one for Black Screen and one for DVD Fab.
I suspect these are a graphic format but I copied one and renamed it BMP, JPG & GIF but couldn't open any of them. Maybe someone else knows what format these are in.
From Google:
So, do either of you guys know of any pre-made CGP files for inserting Disc 1 or Disc 2 messages somewhere, so we can browse through and pick one or more we'd like to use?
CGP (Change Graphic Pictures)
I'm guessing nothing has changed format wise. I don't recall if the monkey has been part of dvdfab since conception maybe someone with an older version say 3 or 4 may have different images.Originally posted by zZz View Post
Otherwise, for some pre-made ones there is a zip file containing several images to choose from @ mrbass. Though I haven't personally tried this on the newer/latest version of dvdfab
To view the images in the file as well as an additional image click on the link below and scroll down just a bit
Confirmed Alternate Images
I tried 2 of the images from the zip file posted @ mrbass link above & they do indeed work
for the 'Split' option -only-. Added images will display in the drop down box under the DVD to DVD Settings option, Split.
What I'm not sure is how to get the 'Customize' option image to work.
Under my brief experiment playing around with 'Customize' & 'Customize Split' I was never able to get an image to be displayed.
The only options are Blank and DVDFab (any additional images don't display on that drop down) however setting it to DVDFab never showed anything different while Customizing a DVD (cut out chapters) or using the Customize Split option.
Not sure if that's a bug or what but I was unable to get a CGP displayed.
