Dvdfab 9 bd rip- no percentage, not ripping
    The day
    I try bd rip and there is no percentage showing and after 4 hrs or so it may say success but file only 10k and doesn't play (work)?
    Trying to rip to avi.xvid.ac3.
    I am selecting only the longest play time file.
    Is there something missing am I doing something wrong?
    I've used DVD rip with no problems before. Is there a different procedure?
    How long should this take.
    I am using a brand new Samsung laptop, and the movie does play from the bd.
    Thanks
    After working at it for awhile, I decided to try another blu-ray. It does rip, but not the whole movie, no matter which chapter I use. Am I missing something?
      It is OK on my site, 27-29 fps.
      Please post the internal.log which has problem.
        I cancelled it but here it is:
        DVDFab 9.0.3.1 (2013/03/22 19:14:17)
        0m 00.24s: Start preload dll...
        0m 00.28s: Load dll successful.
        0m 00.28s: Start load fabplay dll...
        0m 01.60s: Load fabplay dll successful.
        0m 01.60s: Windows os type is: 14.
        0m 01.60s: Transfer settings successful.
        0m 03.36s: GPUAccelerate: 864319
        0m 03.36s: CUDA cap: 1
        0m 03.36s: Support coreavc decode: 0
        0m 03.36s: Graphics info: NVIDIA GeForce GT 630M : 5.0 : 2.1
        0m 03.38s: Qt Translator file load success
        0m 03.49s: Start get sys number.
        0m 03.49s: Serial number is: c8-f7-33-2f-04-62:ca-f7-33-2f-04-5f:c8-f7-33-2f-04-5f:c8-f7-33-2f-04-5e:50-b7-c3-07-6d-5e
        0m 03.49s: Reg URL link is:
        0m 03.49s: Version is: 9031
        0m 03.49s: Product is: 2
        0m 03.49s: Connect type is: 0
        0m 05.38s: Times of connecting error is: 0
        0m 05.39s: Parse string is: 11:8260762964
        0m 05.39s: Parse string is: 21:8260762964
        0m 05.39s: Parse string is: OV:9028
        0m 05.39s: Parse string is: BV:9031
        0m 05.39s: Parse string is: S:9e1f0be225ec55dc8f76f37f93490dd0
        0m 05.57s: End check info.
        0m 05.57s: Load config successful.
        0m 10.66s: Profile Manager :: Begin Load Profile
        0m 10.66s: Init profile data driver sucessful.
        0m 10.66s: Init GPU settings sucessful.
        0m 10.66s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 1
        0m 10.67s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
        0m 15.63s: Begin init preview play engine.
        0m 15.64s: Init DirectShow engine successful.
        0m 16.13s: Init burn engine successful.
        0m 16.32s: opening drive D
        0m 16.33s: opened i/o
        0m 16.33s: got media type 15
        0m 19.67s: got max lba 11506335
        0m 22.25s: Profile Manager :: End Load Profile
        0m 23.70s: got disc type 20
        0m 23.70s: type Blu-ray BDMV
        0m 23.70s: volume label THE_DAY
        0m 23.70s: opening drive D
        0m 23.70s: opened i/o
        0m 23.70s: got media type 15
        0m 26.21s: got max lba 11506335
        0m 29.02s: got disc type 20
        0m 29.02s: type Blu-ray BDMV
        0m 29.02s: volume label THE_DAY
        0m 29.06s: opening drive D
        0m 29.06s: opened i/o
        0m 31.68s: got max lba 11506335
        0m 34.52s: got disc type 20
        0m 34.52s: internal path D:/BDMV/
        0m 34.57s: aacs 1 bd+ 0
        0m 36.10s: got bdmv
        0m 36.10s: Vendor: TSSTcorp
        0m 36.10s: Product: DVDWBD SN-406AB
        0m 36.10s: Revision: SC00
        0m 36.10s: Vendor specific: 0618
        0m 36.10s: AACS version: 1
        0m 36.11s: Number of concurrent AGIDs: 2
        0m 36.11s: Supports bus encryption: YES
        0m 36.11s: Supports binding nonce generation: NO
        0m 36.11s: Supports Hybrid discs: NO
        0m 36.11s: got agid 0
        0m 36.17s: sent host cert chal
        0m 36.17s: got drive cert chal
        0m 36.17s: BEC 1
        0m 36.17s: DRIVE_VENDOR 0x0182
        0m 36.26s: got drive key
        0m 36.26s: got host key signature
        0m 36.26s: verified drive signature
        0m 36.26s: verified host signature
        0m 36.34s: sent host signature and key point
        0m 36.34s: got bus key
        0m 36.35s: got agid 0
        0m 36.41s: sent host cert chal
        0m 36.41s: got drive cert chal
        0m 36.41s: BEC 1
        0m 36.41s: DRIVE_VENDOR 0x0182
        0m 36.50s: got drive key
        0m 36.50s: got host key signature
        0m 36.50s: verified drive signature
        0m 36.50s: verified host signature
        0m 36.58s: sent host signature and key point
        0m 36.58s: got bus key
        0m 36.78s: got volume id
        0m 36.78s: got volume id mac
        0m 36.78s: volume id is correct
        0m 36.78s: got vid
        0m 36.97s: blu-ray 1C57C94A8182263CBFE433B35A1189B77CA7223E
        0m 37.22s: cert BEE=0x00
        0m 38.46s: D 81161B82
        0m 38.46s: got vuk
        0m 38.46s: got agid 0
        0m 38.52s: sent host cert chal
        0m 38.53s: got drive cert chal
        0m 38.53s: BEC 1
        0m 38.53s: DRIVE_VENDOR 0x0182
        0m 38.61s: got drive key
        0m 38.61s: got host key signature
        0m 38.61s: verified drive signature
        0m 38.61s: verified host signature
        0m 38.70s: sent host signature and key point
        0m 38.70s: got bus key
        0m 38.70s: got data key
        0m 38.76s: got unit key 1
        0m 52.94s: Java protection is removed by StealthyClone anti-protection.
        0m 53.03s: got discinfo
        0m 53.13s: got bdmv
        1m 00.27s: got extended bdinfo
        1m 00.28s: opened blu-ray
        1m 05.84s: ========WorkAttr::SetSource=======
        1m 05.84s: Source Title :
        1m 05.84s: Source Video Codec : mpeg2
        1m 05.84s: Source Video Size Original : 1920 x 1036
        1m 05.84s: Source Video Size Display : 1920 x 1036
        1m 05.84s: Source Video FPS : 24000 / 1001
        1m 05.84s: Source Video Bitrate : 1200
        1m 05.85s: Source Audio Codec : aac
        1m 05.85s: Source Audio Bitrate : 0
        1m 05.85s: Source Audio Channels : 6
        1m 05.85s: Source Audio Volume : 100
        1m 05.85s: Work Profile : avi(2gb-).xvid.mp3
        4m 10.14s: ========WorkAttr::SetSource=======
        4m 10.14s: Source Title :
        4m 10.14s: Source Video Codec : mpeg2
        4m 10.14s: Source Video Size Original : 1920 x 1036
        4m 10.14s: Source Video Size Display : 1920 x 1036
        4m 10.14s: Source Video FPS : 24000 / 1001
        4m 10.14s: Source Video Bitrate : 1200
        4m 10.14s: Source Audio Codec : aac
        4m 10.14s: Source Audio Bitrate : 0
        4m 10.14s: Source Audio Channels : 6
        4m 10.14s: Source Audio Volume : 100
        4m 10.14s: Work Profile : avi(2gb-).xvid.mp3
        4m 10.17s: ========WorkAttr::SetSource=======
        4m 10.17s: Source Title :
        4m 10.17s: Source Video Codec : mpeg2
        4m 10.17s: Source Video Size Original : 1920 x 1036
        4m 10.17s: Source Video Size Display : 1920 x 1036
        4m 10.17s: Source Video FPS : 24000 / 1001
        4m 10.18s: Source Video Bitrate : 1200
        4m 10.18s: Source Audio Codec : aac
        4m 10.18s: Source Audio Bitrate : 0
        4m 10.18s: Source Audio Channels : 6
        4m 10.18s: Source Audio Volume : 100
        4m 10.18s: Work Profile : avi(2gb-).xvid.mp3
        4m 46.12s: Start check Blu-ray Ripper register status.
        4m 46.12s: End check Blu-ray Ripper register status: Enable
        4m 46.13s: OPList at BD Ripper : (4113.2),(4352.2),(4608.8)
        4m 46.13s: Blu-ray ripper check watermark flag: 0
        4m 46.13s: ------------------ convert work begin(1/1) ------------------
        4m 46.13s: info: create config(bluray2video)
        4m 46.13s: info: use profile(avi(2gb-).xvid.mp3)
        4m 46.13s: info: bluray playlist(1),angle(0),chapter(1->13),BDAV(no)
        4m 46.13s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
        4m 46.15s: info: [Video]stream(4113) codec(h264) opcode(compress)
        4m 46.15s: info: set output video frame_rate(24000/1001)
        4m 46.16s: info: [Audio]stream(4352) codec(truehd) opcode(compress) channel(6)
        4m 46.16s: info: SubMode(Render) -- Display only forced subpicture(false)
        4m 46.16s: info: [Sub]stream(4608) codec(pgssub) opcode(render) language(English)
        4m 46.16s: try to use gpu acceleration(5) for video decoding
        4m 46.16s: Intel GPU acceleration for video decoding enabled
        4m 50.65s: info: connect to sub render filter success.
        4m 52.65s: info: processing source(00001.m2ts)
        53m 11.72s: ------------------ all convert work cancelled -------------------
        53m 20.85s: ========WorkAttr::SetSource=======
        53m 20.85s: Source Title :
        53m 20.85s: Source Video Codec : mpeg2
        53m 20.85s: Source Video Size Original : 1920 x 1036
        53m 20.85s: Source Video Size Display : 1920 x 1036
        53m 20.85s: Source Video FPS : 24000 / 1001
        53m 20.85s: Source Video Bitrate : 1200
        53m 20.85s: Source Audio Codec : aac
        53m 20.85s: Source Audio Bitrate : 0
        53m 20.85s: Source Audio Channels : 6
        53m 20.85s: Source Audio Volume : 100
        53m 20.85s: Work Profile : avi(2gb-).xvid.mp3
          Try it not using the 2GB- profile.
            Hi Justlearning_1
            2 things to try
            1st go into Fab settings and disable Cuda and set all to using software.
            2nd try a different AVI profile, not one of the (2gb-)
            Hope this helps
            CBR929
              Thanks all.
              I am able to rip now. At first I tried to rip to avi, but sound was out., so I ripped to MKV which seems fine, although the file size is over 8 Gig.
              I thought I read somewhere it is best to convert after it is ripped to hard drive.
              Thanks again
                Hi Justlearning_1
                Glad you got it!!!
                You may be able to adjust the output size in advanced settings.
                You are correct, it's always better to copy to your Hdd first, then do your converting.
                Doing it this way saves wear and tear on your optical drive.
                CBR929
