jack reacher
    Finally sorted it by selecting main movie only which is a shame as you don't get the main menu function, this V9 is going to take some getting used to over the simplicity of the V8.
      Hi Mickey, i have been using Taiyo yuden 8x which i think make verbatim but don't hold me to that. I guess if you use DL discs you get movie,menu's etc all on the disc?
        jack reacher
        hi neil 1975,
        yes they are very good discs, i use dl discs so i just clone the hole disc with no loss and are as good as the main disc, whatever on the main disc is on the clone,with read and writing time of about 1hour total. try using dl and see how you get on.
        regards
          I will try them mickey and thanks for the heads up.
            Be sure to get +R DL Verbatims and look for the AZO on the label, that is the organic dye that make all the difference. Don't use -R DL discs for video.
              jack reacher
              hi 90312,
              thanks for that, I forgot to say that in my last post.
              regards
                Thanks for the info on them 90312, what are your opinions on the RITEK 8X DL DUAL LAYER DVD+R?
                  I have used RITEK early on Neil and would probably avoid them now. They make good copies at a reasonable failure rate, but they didn't last long. When I'd go back to watch in a few months no video on the disc and that's where the AZO dye comes in, Verbatim copies seem to last forever. I'm sure the RITEK will make a copy but keep the original handy you'll need it again!
                    Verbatim it is then,thanks again mickey and 90312.
                      Please try the latest beta found here
                      If still having problems post your internal log.
                      Thank
                      CBR929
                      Will there be a fix for V8? I tried V9 and just could not get use to or figure out it's User Interface.
                        Hi noseph
                        No, version 8 "Sleeps with the Fishes"
                        CBR929
                          If V8 is sleeping with the fishes, it might be time to go fishing.
                            Jack Reacher
                            V8 does not work, V9 interface sucks, but it does not work either.
                            Will go try the Mac version next.
                              Ozzie this is a completely useless post. You've been around long enough to know the routine. Future posts like this will be deleted without notice.
                                Trying to give V9 a fair shake. I had been using the V8 iPad profile to rip DVDs for play back on my ROKU, however none of the iPad profiles in V9 will produce a .m4v that will play on my ROKU. Any suggestions as to a comparable V9 profile to the V8 iPad profile or preferably a V9 ROKU profile.
