noseph, in the meantime you can do what I did with Jack Reacher, I used v9 copy to rip it to the HDD and then used V8 on the HDD folder (as the source for V8) to make my mobile device files. V9 will put a clean unprotected folder or iso on the HDD that V8 will open and manipulate for you.
jack reacher
Originally posted by 90312 View Postnoseph, in the meantime you can do what I did with Jack Reacher, I used v9 copy to rip it to the HDD and then used V8 on the HDD folder (as the source for V8) to make my mobile device files. V9 will put a clean unprotected folder or iso on the HDD that V8 will open and manipulate for you.
Glad it's working for you and I'm sure future updates will fix these bugs, these are beta releases after all.How to post the internal log
Originally posted by fengtao View PostHi,
Please help us in following steps:
1. Open the disc with PathPlayer enabled.
2. "Save Info Files" for v8, or "Export Source Info" for v9.
3. Zip all files in "<user>\Documents\DVDFab\Log\" for v8, or "<user>\Documents\DVDFab9\Log\" for v9.
4. Send the zip file to fengtao(at)dvdfab.com.
Thank you very much!
Best Regards,
Fengtao
I have followed the instructions and sent you the zip file.
Thanks for your help.
