Kindle Fire HD
    Kindle Fire HD
    It's me again, I thank you 90312 for your help in the past, you did guide me through the process of ripping backup DVDs to Kindle Fire HD.
    This worked great on older titles, like Dracula and Flattop these are two older movies possibly without being encrypted.
    I tried 4 more recent titles such as LOL, Jack Reacher, Lincoln and Safe Haven.
    Using the same process as I did for the order titles, but when I tried to play them on my Kindle Fire HD, a box popped up and said
    "Unable to play video
    sorry, this vidoe cannot be played
    OK"
    My backup DVDs are Region R1, if you can help me in any way by duplicating my problem and help me correct it I'd be very thankful.
    Thank you in advance,
    apollo13
    have a good day
    This could be an issue with the software, the PSP 3.30+ profile has been broken for a few updates now and is still so in 9.0.3.9beta. Try one of the movies that worked in the version you are using now and if that works on your Kindle we have a starting point.
      Hi, did use the new 9.0.3.9beta
      when idid these dvd's.
      never did work for me on any verison since i've been doing Kindle
        So some movies work and some don't made with 9.0.3.9beta? If that is so post a complete internal log for one that works and one that don't. It may take someone smarter than me to sort it out.
          ok it will take awhile, i'll post them when done ty hagd
            hi you there,
            logs won't copy and paste for some reason
              Go for 90312!
                  they should paste in here right?
                    (Log On Flat Top) Playes on Kindle Fire HD
                    DVDFab 9.0.3.9 (2013/05/10 13:02:36)
                    0m 00.12s: Start preload dll...
                    0m 00.17s: Load dll successful.
                    0m 00.17s: Start load fabplay dll...
                    0m 00.23s: Load fabplay dll successful.
                    0m 00.23s: Windows os type is: 14.
                    0m 00.23s: Transfer settings successful.
                    0m 00.35s: GPUAccelerate: 3
                    0m 00.35s: CUDA cap: 0
                    0m 00.35s: Support coreavc decode: 0
                    0m 00.35s: Graphics info: : :
                    0m 00.35s: import key file D:\ 1
                    0m 00.35s: Load config successful.
                    0m 00.35s: Qt Translator file load success
                    0m 00.40s: Start get sys number.
                    0m 00.40s: Serial number is: 00-1c-c0-b1-53-f6
                    0m 00.40s: Reg URL link is:
                    0m 00.40s: Version is: 9039
                    0m 00.40s: Product is: 2
                    0m 00.40s: Connect type is: 0
                    0m 01.73s: Profile Manager :: End Load Profile
                    0m 05.00s: Times of connecting error is: 0
                    0m 05.00s: Parse string is: 2:8260762964
                    0m 05.00s: Parse string is: 11:8260762964
                    0m 05.00s: Parse string is: 20:8260762964
                    0m 05.00s: Parse string is: 50:8260762964
                    0m 05.00s: Parse string is: 80:8260762964
                    0m 05.00s: Parse string is: 21:8260762964
                    0m 05.00s: Parse string is: 22:8260762964
                    0m 05.00s: Parse string is: 60:8260762964
                    0m 05.00s: Parse string is: 70:8260762964
                    0m 05.00s: Parse string is: 200:1379947896
                    0m 05.00s: Parse string is: 1:17
                    0m 05.00s: Parse string is: OV:9038
                    0m 05.00s: Parse string is: BV:9039
                    0m 05.00s: Parse string is: S:d1337fd8abb9c79fc6e652b91a32cb91
                    0m 05.03s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
                    0m 05.03s: End check info.
                    0m 05.14s: Init profile data driver sucessful.
                    0m 05.14s: Init GPU settings sucessful.
                    0m 08.86s: Begin init preview play engine.
                    0m 09.07s: Init internal engine successful.
                    0m 09.23s: Init burn engine successful.
                    0m 09.44s: opening drive D
                    0m 09.44s: opened i/o
                    0m 09.44s: got media type 12
                    0m 09.50s: got max lba 1850319
                    0m 09.55s: got disc type 10
                    0m 10.58s: type DVD-VIDEO
                    0m 10.58s: volume label FLAT_TOP
                    0m 10.60s: opening drive E
                    0m 10.61s: opened i/o
                    0m 10.61s: failed to detect media type: sensekey 00 asc 00 acsq 00
                    0m 10.61s: failed to get max lba: sensekey 02 asc 3A acsq 01
                    0m 10.68s: internal path D:/VIDEO_TS/
                    0m 10.69s: failed to report agid: sensekey 00 asc 00 acsq 00
                    0m 10.90s: failed to report agid: sensekey 00 asc 00 acsq 00
                    0m 11.31s: failed to report agid: sensekey 00 asc 00 acsq 00
                    0m 11.52s: failed to report agid: sensekey 00 asc 00 acsq 00
                    0m 11.93s: failed to report agid: sensekey 00 asc 00 acsq 00
                    0m 12.14s: failed to report agid: sensekey 00 asc 00 acsq 00
                    0m 12.54s: got copyright 0 0
                    0m 12.88s: got udf/iso
                    0m 13.50s: got discinfo
                    0m 13.50s: pathplayer enabled
                    0m 13.60s: button: vts_1 menu_1 pgc_7 cell_1 sector_0 count_2
                    0m 20.94s: button: vts_1 menu_1 pgc_8 cell_1 sector_54 count_10
                    0m 20.97s: button: vts_1 menu_1 pgc_9 cell_1 sector_142 count_10
                    0m 20.99s: button: vts_1 menu_1 pgc_10 cell_1 sector_227 count_10
                    0m 21.01s: button: vts_1 menu_1 pgc_11 cell_1 sector_308 count_10
                    0m 21.04s: button: vts_1 menu_1 pgc_12 cell_1 sector_394 count_10
                    0m 21.13s: button: vts_1 menu_1 pgc_13 cell_1 sector_476 count_2
                    0m 21.62s: got dvdinfo
                    0m 21.62s: opened dvd
                    0m 27.05s: ========WorkAttr::SetSource=======
                    0m 27.05s: Source Title :
                    0m 27.05s: Source Video Size Original : 720 x 547
                    0m 27.05s: Source Video Size Display : 631 x 480
                    0m 27.05s: Source Video FPS : 30000 / 1001
                    0m 27.05s: Source Video Bitrate : 1200
                    0m 27.05s: Source Audio Bitrate : 192000
                    0m 27.05s: Source Audio Channels : 2
                    0m 27.05s: Source Audio Volume : 100
                    0m 27.05s: Work Profile : Kindle Fire HD.default
                    0m 27.23s: CommmandLine in fabopensource is "D:\"
                    2m 03.57s: ========WorkAttr::SetSource=======
                    2m 03.57s: Source Title :
                    2m 03.57s: Source Video Size Original : 720 x 547
                    2m 03.57s: Source Video Size Display : 631 x 480
                    2m 03.58s: Source Video FPS : 30000 / 1001
                    2m 03.58s: Source Video Bitrate : 1200
                    2m 03.58s: Source Audio Bitrate : 192000
                    2m 03.58s: Source Audio Channels : 2
                    2m 03.58s: Source Audio Volume : 100
                    2m 03.58s: Work Profile : Kindle Fire HD.default
                    2m 03.79s: ========WorkAttr::SetSource=======
                    2m 03.79s: Source Title :
                    2m 03.79s: Source Video Size Original : 720 x 547
                    2m 03.79s: Source Video Size Display : 631 x 480
                    2m 03.79s: Source Video FPS : 30000 / 1001
                    2m 03.79s: Source Video Bitrate : 1200
                    2m 03.79s: Source Audio Bitrate : 192000
                    2m 03.79s: Source Audio Channels : 2
                    2m 03.79s: Source Audio Volume : 100
                    2m 03.79s: Work Profile : Kindle Fire HD.default
                    5m 11.88s: ========WorkAttr::SetSource=======
                    5m 11.88s: Source Title :
                    5m 11.88s: Source Video Size Original : 720 x 547
                    5m 11.88s: Source Video Size Display : 631 x 480
                    5m 11.88s: Source Video FPS : 30000 / 1001
                    5m 11.88s: Source Video Bitrate : 1200
                    5m 11.88s: Source Audio Bitrate : 192000
                    5m 11.88s: Source Audio Channels : 2
                    5m 11.88s: Source Audio Volume : 100
                    5m 11.88s: Work Profile : Kindle Fire HD.default
                    5m 11.90s: ========WorkAttr::SetSource=======
                    5m 11.90s: Source Title :
                    5m 11.90s: Source Video Size Original : 720 x 547
                    5m 11.90s: Source Video Size Display : 631 x 480
                    5m 11.90s: Source Video FPS : 30000 / 1001
                    5m 11.90s: Source Video Bitrate : 1200
                    5m 11.90s: Source Audio Bitrate : 192000
                    5m 11.90s: Source Audio Channels : 2
                    5m 11.90s: Source Audio Volume : 100
                    5m 11.90s: Work Profile : Kindle Fire HD.default
                    6m 41.32s: ========WorkAttr::SetSource=======
                    6m 41.32s: Source Title :
                    6m 41.32s: Source Video Size Original : 720 x 547
                    6m 41.33s: Source Video Size Display : 631 x 480
                    6m 41.33s: Source Video FPS : 30000 / 1001
                    6m 41.33s: Source Video Bitrate : 1200
                    6m 41.33s: Source Audio Bitrate : 192000
                    6m 41.33s: Source Audio Channels : 2
                    6m 41.33s: Source Audio Volume : 100
                    6m 41.33s: Work Profile : Kindle Fire HD.default
                    7m 38.37s: ========WorkAttr::SetSource=======
                    7m 38.37s: Source Title :
                    7m 38.37s: Source Video Size Original : 720 x 547
                    7m 38.37s: Source Video Size Display : 631 x 480
                    7m 38.37s: Source Video FPS : 30000 / 1001
                    7m 38.37s: Source Video Bitrate : 1200
                    7m 38.37s: Source Audio Bitrate : 192000
                    7m 38.37s: Source Audio Channels : 2
                    7m 38.37s: Source Audio Volume : 100
                    7m 38.37s: Work Profile : Kindle Fire HD.default
                    8m 13.75s: ========WorkAttr::SetSource=======
                    8m 13.75s: Source Title :
                    8m 13.75s: Source Video Size Original : 720 x 547
                    8m 13.75s: Source Video Size Display : 631 x 480
                    8m 13.75s: Source Video FPS : 30000 / 1001
                    8m 13.75s: Source Video Bitrate : 1200
                    8m 13.75s: Source Audio Bitrate : 192000
                    8m 13.75s: Source Audio Channels : 2
                    8m 13.75s: Source Audio Volume : 100
                    8m 13.75s: Work Profile : Kindle Fire HD.default
                    8m 59.58s: Start check DVD Ripper register status.
                    8m 59.58s: End check DVD Ripper register status: Enable
                    8m 59.58s: OPList at DVD Ripper : (480.2),(128.2)
                    8m 59.58s: DVD ripper check watermark flag: 0
                    8m 59.59s: ------------------ convert work begin(1/1) ------------------
                    8m 59.59s: info: create config(dvd2video)
                    8m 59.59s: info: use profile(Kindle Fire HD.default)
                    8m 59.59s: info: dvd playlist(4),angle(0),chapter(1->22)
                    8m 59.59s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
                    9m 02.48s: info: video stream[480][codec(mpeg2video) opcode(compress)]
                    9m 02.48s: info: set output video frame_rate(30000/1001)
                    9m 02.48s: info: audio stream[128][codec(ac3) channels(2) sample(48000) bitrate(192000) opcode(compress)]
                    9m 02.48s: info: Subtitle Mode(NoSub) -- Display only forced Subtitle(false)
                    9m 03.63s: info: h264_encode: encode param profile(1) level(40) bitrate(2300)
                    68m 58.03s: audio_decode finish job
                    68m 58.09s: audio_encode finish job
                    69m 58.08s: ------------------ convert work finished ------------------
                      (Log On Safe Haven) Will Not Playes on Kindle Fire HD
                      DVDFab 9.0.3.9 (2013/05/10 15:12:05)
                      0m 00.14s: Start preload dll...
                      0m 00.18s: Load dll successful.
                      0m 00.18s: Start load fabplay dll...
                      0m 00.24s: Windows os type is: 14.
                      0m 00.24s: Transfer settings successful.
                      0m 00.39s: GPUAccelerate: 3
                      0m 00.39s: CUDA cap: 0
                      0m 00.39s: Support coreavc decode: 0
                      0m 00.39s: Graphics info: : :
                      0m 00.39s: import key file D:\ 1
                      0m 00.39s: Load config successful.
                      0m 00.39s: Qt Translator file load success
                      0m 00.43s: Start get sys number.
                      0m 00.43s: Serial number is: 00-1c-c0-b1-53-f6
                      0m 00.43s: Reg URL link is:
                      0m 00.43s: Version is: 9039
                      0m 00.43s: Product is: 2
                      0m 00.43s: Connect type is: 0
                      0m 01.80s: Profile Manager :: End Load Profile
                      0m 03.99s: Times of connecting error is: 0
                      0m 03.99s: Parse string is: 2:8260762964
                      0m 03.99s: Parse string is: 11:8260762964
                      0m 03.99s: Parse string is: 20:8260762964
                      0m 03.99s: Parse string is: 50:8260762964
                      0m 03.99s: Parse string is: 80:8260762964
                      0m 03.99s: Parse string is: 21:8260762964
                      0m 03.99s: Parse string is: 22:8260762964
                      0m 03.99s: Parse string is: 60:8260762964
                      0m 03.99s: Parse string is: 70:8260762964
                      0m 03.99s: Parse string is: 200:1379947896
                      0m 03.99s: Parse string is: 1:17
                      0m 03.99s: Parse string is: OV:9038
                      0m 03.99s: Parse string is: BV:9039
                      0m 03.99s: Parse string is: S:4176b8cbbcf78e54546c24a4e0f256ca
                      0m 04.04s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1
                      0m 04.04s: End check info.
                      0m 04.13s: Init profile data driver sucessful.
                      0m 04.13s: Init GPU settings sucessful.
                      0m 07.87s: Begin init preview play engine.
                      0m 08.00s: Init internal engine successful.
                      0m 08.24s: Init burn engine successful.
                      0m 08.44s: opening drive D
                      0m 08.44s: opened i/o
                      0m 08.44s: got media type 11
                      0m 08.53s: got max lba 2295103
                      0m 08.54s: got disc type 10
                      0m 08.56s: type DVD-VIDEO
                      0m 08.56s: volume label SAFE_HAVEN
                      0m 08.75s: opening drive E
                      0m 08.76s: opened i/o
                      0m 08.76s: failed to detect media type: sensekey 00 asc 00 acsq 00
                      0m 08.76s: failed to get max lba: sensekey 02 asc 3A acsq 01
                      0m 08.83s: internal path D:/VIDEO_TS/
                      0m 08.83s: failed to report agid: sensekey 00 asc 00 acsq 00
                      0m 09.04s: failed to report agid: sensekey 00 asc 00 acsq 00
                      0m 09.45s: failed to report agid: sensekey 00 asc 00 acsq 00
                      0m 09.66s: failed to report agid: sensekey 00 asc 00 acsq 00
                      0m 10.07s: failed to report agid: sensekey 00 asc 00 acsq 00
                      0m 10.28s: failed to report agid: sensekey 00 asc 00 acsq 00
                      0m 10.68s: got copyright 0 0
                      0m 10.96s: got udf/iso
                      0m 11.97s: got discinfo
                      0m 11.97s: pathplayer enabled
                      0m 12.76s: button: vts_2 menu_1 pgc_22 cell_1 sector_336 count_4
                      0m 15.99s: button: vts_2 menu_1 pgc_28 cell_1 sector_182 count_6
                      0m 16.05s: button: vts_2 menu_1 pgc_23 cell_1 sector_0 count_13
                      0m 16.07s: button: vts_2 menu_1 pgc_23 cell_2 sector_46 count_13
                      0m 16.11s: button: vts_2 menu_1 pgc_23 cell_3 sector_91 count_13
                      0m 16.14s: button: vts_2 menu_1 pgc_23 cell_4 sector_136 count_13
                      0m 16.21s: button: vts_2 menu_1 pgc_32 cell_1 sector_7761 count_6
                      0m 16.22s: button: vts_2 menu_1 pgc_33 cell_1 sector_7789 count_8
                      0m 18.08s: button: vts_2 menu_1 pgc_34 cell_1 sector_7733 count_5
                      0m 22.22s: got dvdinfo
                      0m 22.22s: opened dvd
                      0m 26.86s: ========WorkAttr::SetSource=======
                      0m 26.86s: Source Title :
                      0m 26.87s: Source Video Size Original : 720 x 303
                      0m 26.87s: Source Video Size Display : 854 x 360
                      0m 26.87s: Source Video FPS : 24000 / 1001
                      0m 26.87s: Source Video Bitrate : 1200
                      0m 26.87s: Source Audio Bitrate : 448000
                      0m 26.87s: Source Audio Channels : 6
                      0m 26.87s: Source Audio Volume : 100
                      0m 26.87s: Work Profile : Kindle Fire HD.default
                      0m 27.20s: CommmandLine in fabopensource is "D:\"
                      0m 48.11s: ========WorkAttr::SetSource=======
                      0m 48.11s: Source Title :
                      0m 48.11s: Source Video Size Original : 720 x 303
                      0m 48.11s: Source Video Size Display : 854 x 360
                      0m 48.11s: Source Video FPS : 24000 / 1001
                      0m 48.11s: Source Video Bitrate : 1200
                      0m 48.11s: Source Audio Bitrate : 448000
                      0m 48.11s: Source Audio Channels : 6
                      0m 48.11s: Source Audio Volume : 100
                      0m 48.11s: Work Profile : Kindle Fire HD.default
                      4m 11.41s: Start check DVD Ripper register status.
                      4m 11.41s: End check DVD Ripper register status: Enable
                      4m 11.42s: OPList at DVD Ripper : (480.2),(128.2),(32.8)
                      4m 11.42s: DVD ripper check watermark flag: 0
                      4m 11.42s: ------------------ convert work begin(1/1) ------------------
                      4m 11.42s: info: create config(dvd2video)
                      4m 11.42s: info: use profile(Kindle Fire HD.default)
                      4m 11.42s: info: dvd playlist(7),angle(0),chapter(1->17)
                      4m 11.42s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
                      4m 14.20s: info: video stream[480][codec(mpeg2video) opcode(compress)]
                      4m 14.20s: info: set output video frame_rate(30000/1001)
                      4m 14.20s: info: audio stream[128][codec(ac3) channels(5) sample(48000) bitrate(448000) opcode(compress)]
                      4m 14.20s: info: Subtitle Mode(Render) -- Display only forced Subtitle(false)
                      4m 14.22s: info: subtitle stream[32][codec(dvdsub) language(English) opcode(render)]
                      4m 15.33s: info: h264_encode: encode param profile(1) level(40) bitrate(2300)
                      4m 17.35s: info: connect to sub render filter success.
                      4m 53.27s: audio_decode finish job
                      4m 54.34s: ------------------ all convert work cancelled -------------------
                      6m 17.08s: ========WorkAttr::SetSource=======
                      6m 17.08s: Source Title :
                      6m 17.08s: Source Video Size Original : 720 x 303
                      6m 17.08s: Source Video Size Display : 854 x 360
                      6m 17.08s: Source Video FPS : 24000 / 1001
                      6m 17.08s: Source Video Bitrate : 1200
                      6m 17.08s: Source Audio Bitrate : 448000
                      6m 17.08s: Source Audio Channels : 6
                      6m 17.08s: Source Audio Volume : 100
                      6m 17.08s: Work Profile : Kindle Fire HD.default
                      7m 20.04s: Start check DVD Ripper register status.
                      7m 20.04s: End check DVD Ripper register status: Enable
                      7m 20.04s: OPList at DVD Ripper : (480.2),(128.2)
                      7m 20.04s: DVD ripper check watermark flag: 0
                      7m 20.04s: ------------------ convert work begin(1/1) ------------------
                      7m 20.04s: info: create config(dvd2video)
                      7m 20.04s: info: use profile(Kindle Fire HD.default)
                      7m 20.05s: info: dvd playlist(7),angle(0),chapter(1->17)
                      7m 20.05s: info: 3D working_mode(disable), 3D format(sbs_lef_right)
                      7m 23.09s: info: video stream[480][codec(mpeg2video) opcode(compress)]
                      7m 23.10s: info: set output video frame_rate(30000/1001)
                      7m 23.10s: info: audio stream[128][codec(ac3) channels(5) sample(48000) bitrate(448000) opcode(compress)]
                      7m 23.10s: info: Subtitle Mode(NoSub) -- Display only forced Subtitle(false)
                      7m 24.24s: info: h264_encode: encode param profile(1) level(40) bitrate(2300)
                      91m 51.92s: audio_decode finish job
                      91m 57.06s: audio_encode finish job
                      92m 59.28s: ------------------ convert work finished ------------------
                      3 or 4 other titles I stated above will also not play!!!!!
                      ty hagd
                      apollo13
                        there they went!!!!!!!!!!
                          Looks like the one that played has 2 audio channels and the one that won't has 5 channels. That device probably won't play 5.1 audio, try down mixing the audio to stereo and give it a try.
                            it the movie that won't play no picture.
                            all the dvd's play on pc and stand alone players,
                            that's what i don't under stand.
                            why not Kindle Fire HD?
                              Try it you might like it.
