Anyone having a problem burning with 9.039?
    I can copy (Main Movie) to the HDD but later when trying to burn to a DVD it doesn't find the files. Anyone else seeing this?
    I know their there and fine as an old copy of version 8 burns them just fine.
    It's a known and posted issue, drag and drop the folder onto DVDFab and it will work ok.
      My Bad. Guess I should should have done some digging. Thank you for the quick reply.
        No problem, you may have downloaded before the change log was revised. Working for you now?
          9.0.3.9 beta
          I had similar problem. Had 9.0.3.8 and could not burn Jack Reacher to hard drive. I found the 9.0.3.9 beta and installed that. It did burn Reacher to the hard drive like normal but It would not any way I tried, burn back the movie to dvd disc. It would not even find the video files. Total blank.
          What I had to do was uninstall 9039beta, and then reinstall the 9038. This located the video ts files and burnt the dvd ok.
          9039 beta had to have some bug in it somewhere, and I hope this is not the way things are going to be.
          9039 looks promising, but right now it is a pain in the rear.
          And the drag and drop option did not work at all no matter how many times I tried.
          Last edited by edistoriverrat; 05-11-2013, 11:51 PM. Reason: added a few more words
            DVD Fab Invisible
            Has anyone heard of "DVD Fab Invisible" coming up after DVD fab is exited completely?
              @Fabman
              Do not double post. Start your own thread!!
                Hi Fabman
                Do not hijack anyone's thread, future hijacks will have your posts deleted.
                As my friend said start your own thread with your problem.
                This is your warning...
                CBR929
