Dear Forum
Can anyone assist, I had problems with ripping an old DVD movie, DVDFAB has a problem, it scan it and there were no error message. It just scan and scan and scan.
I looked at the playable side of the DVD and found it to be moulded, so I took out the DVD and clean it with glass cleaner,
I rescan it with DVDFAB, still same problem and I tried to play it at my player, it cannot play. (I was able to play before the cleaning). I already tried on 3 different players and PCs.
What has happened? I cannot read the DVD anymore, have I destroy it? Is there any way to cure it?
Can anyone help?
Thank you
P/s:- I am not too sure if this posting should be in GENERAL or CHAT. Please move it if it is not correct.....Sorry.
Can anyone help?
Thank you
