Question about HD Decrypter
    License/Key Question about HD Decrypter
    Hello
    Maybe someone can answer this for me. I have been using HD Decrypter with no problems for a long time. Now I am unable to use it. When I select the HD Decrypter and click Try It it starts to load my Blu Ray and then gives me a message that I need to Buy or renew Blu Ray Copy to load the Blu Ray. Did something change? Does HD Decrypter no longer support Blu Ray discs....totally confused. I am using 9.1.4.6, I have tried uninstalling and reinstalling the software to no avail. ANy help would be greatly appreciated.
    Thanks
    Tom
    I cant even buy a license since i am in the US
      For USA users, we are working on a solution. Please kindly wait. You can contact service team for more detail via the contact page...
      DVDFab contact page in order for you to contact our specialist for any problem you might encounter while using DVDFab, the fastest DVD to IPOD conversion software.
      Hope this help you!
