How to rip DVD, avoiding bad spot
    I have a DVD with a bad spot on it (I/O error) that cleaning, etc, does not correct. How can I make a copy of this DVD, skipping over the bad spot?
    (Note that the error prevents DVDFab from completing its initial scan.)
    give this a try - http://www.videohelp.com/tools/IsoPuzzle
      Yes, that solved my problem. Tx October262!
