While updating to the latest software I have multiply errors. I hit retry and they worked, but I got the warning" Qt Platform plugin Windows". It won"t run even after I have uninstalled, Used an earlier version and used a restore point several days earlier. What can I do?
Update Problem
Hi,kensue49
Please go to C:/Program Files/DVDFab 9/platforms folder, and delete is-KPITD.tmp file, then restart DVDFab to see the result.
If cannot find is-KPITD.tmp file in DVDFab 9/platforms folder, please click Tool button>Folder option>View, to tick "Show hidden file, folders, and drive", and then you should find that file.
Check if there is any other files rather than just,
if yes, only keep the three files and delete all other files.Last edited by geilee; 08-20-2014, 04:22 AM.
Please re-download DVDFab and reinstall DVDFab.
Please tell us the result.
WilsonPlease post your logs the default location is:
