Tropic Thunder Problem?
    It will open the DVD up but when copy the DVD it hangs at 80.10%.
    Ive cleaned the Disc (no visable scratching)
    I have tried 3 times now and each time it will lock up at the same time.
    Any Ideas ?
    Hi Lizardking. The mods will probably tell you anyhow, but you ned more info.
    click on this and then post back after reading.
      oh i understand about logs but once DVD hits that 80.10% it does Not Responding and I have to end that task so therefore nothing gets written to a log.
      tried the disk in 2 other players and movie plays..
        Sounds dumb but check for scratches or grease on the dvd.
          Take a run through this list:
