Newest Version Doesn't Allow for Compression to 4.7gb DVD?
    Clone is a 1 to 1 copy and there is no size selection. Select full disk if you want the menus and extra stuff. And yes you can select the iso on the HDD as the source and compress.
    As I suspected you were using Clone which does not have the option to compress as my friend said, your also using an older version the newest can be found here http://forum.dvdfab.cn/showthread.php?t=26358
    CBR929
