Can't Copy DVD of My Kid's Performance
    My kids performed in a competition a couple of weekends ago. We bought a DVD of the thing and would like to rip it so we can watch it with the rest of our home videos, but it seems like it has some sort of primitive copy protection, so there's all sorts of blocky garbage at the bottom of the screen. The top 3/4s to 7/8s of the screen is fine.
    Also, considering it was direct to DVD, it looks like it's interlaced.
    Anyway, anyone got any suggestions for ripping low-rent 'homemade' DVDs?
    Thanks,
    Peter
    try using the "clone feature option"
      I'm looking in the ripping menus, video effects and conversion settings and I don't see a "Clone Feature" option anywhere.
      Where would I find this, and how does it help rip a video to a file?
        The "Clone" option is in the Copy portion of DVDFab. It's for ripping and burning DVDs as-is. Are you trying to make copies of the DVD? Or are you trying to make a file on your computer's hard drive?
          click on the blue square on the left side of the program where it says "full disc"
          and just select clone/burn option
            Sorry, I guess I wasn't clear. I wanted to rip it to a file, not burn another CD copy. It's when I rip the file that all the junk shows up at the bottom.
            And it's not like, at the bottom, off the frame. It overlaps the actual content.
            Peter
              Please post the DVDFab internal log file. Thanks!
                ------ finish mobile work ------
                DVDFab 8.2.2.6 (2015/02/05 18:04:23)
                0m 06.21s: GPUAccelerate: 851973
                0m 06.21s: CUDA cap: 0
                0m 06.21s: Support coreavc decode: 0
                0m 06.21s: Graphics info: Intel(R) HD Graphics Family : :
                0m 06.24s: Qt Translator file load success
                0m 06.28s: Load config successful.
                0m 06.46s: Init profile data driver sucessful.
                0m 07.26s: Init GPU settings sucessful.
                0m 07.26s: option dvd2dvd 1 dvd2mobile 1 bluray2bluray 1 bd2mobile 1 bd23d 1 bd2dvd 1 file2dvd 1 file2bluray 1 file2mobile 1 filemover 0
                0m 07.26s: dvd2dvd:dvd2mobile:blu-ray2blu-ray:blu-ray2mobile:blu-ray23d:blu-ray2dvd:file2mobile:file2dvd:file2bluray:
                0m 07.33s: Config ExBar successful.
                0m 07.33s: dvd2dvd have 8 elements.
                0m 07.43s: dvd2mobile have 16 elements.
                0m 07.67s: blu-ray2blu-ray have 0 elements.
                0m 07.68s: blu-ray2mobile have 0 elements.
                0m 07.68s: blu-ray23d have 0 elements.
                0m 07.68s: blu-ray2dvd have 0 elements.
                0m 07.68s: file2mobile have 0 elements.
                0m 07.68s: file2dvd have 0 elements.
                0m 07.68s: file2bluray have 0 elements.
                0m 07.76s: Config work ui controls successful.
                0m 07.94s: Init burn engine successful.
                0m 07.98s: StartNotify successful.
                0m 30.38s: opening drive D
                0m 30.39s: opened i/o
                0m 30.39s: got media type 5
                0m 30.66s: got max lba 524031
                0m 30.66s: got disc type 10
                0m 30.70s: type DVD-VIDEO
                0m 30.70s: volume label FUNAI_VIDEO_RECORDING
                0m 30.74s: internal path D:/VIDEO_TS/
                0m 30.76s: failed to read disc key: sensekey 00 asc 00 acsq 00
                0m 30.99s: failed to read disc key: sensekey 00 asc 00 acsq 00
                0m 31.20s: failed to read disc key: sensekey 00 asc 00 acsq 00
                0m 31.40s: got copyright 0 0
                0m 31.80s: got udf/iso
                0m 32.29s: got discinfo
                0m 32.29s: pathplayer enabled
                0m 32.35s: button: vts_0 menu_1 pgc_1 cell_1 sector_0 count_11
                0m 37.91s: no main title, turn off pathplayer
                0m 38.04s: got dvdinfo
                0m 38.04s: opened dvd
                0m 43.49s: WorkAttr::Init Start
                0m 43.55s: WorkAttr::Init OK: appletv.default
                1m 31.18s: WorkAttr::Init Start
                1m 31.22s: WorkAttr::Init OK: iphone.default
                1m 34.46s: WorkAttr::Init Start
                1m 34.47s: WorkAttr::Init OK: AppleTV
                1m 35.95s: WorkAttr::Init Start
                1m 35.99s: WorkAttr::Init OK: appleTV - 640
                1m 36.44s: WorkAttr::Init Start
                1m 36.45s: WorkAttr::Init OK: iPhone5.h264.1080p
                1m 37.54s: WorkAttr::Init Start
                1m 37.54s: WorkAttr::Init OK: iphone - 480
                1m 39.58s:
                ------ begin mobile work(1/2) ------
                1m 39.58s: info: create config(0)
                1m 39.58s: info: convert profile(appleTV - 640)
                1m 39.58s: info: dvd playlist(1),angle(0),chapter(1->5),3D(0)
                1m 39.58s: info: streams((480.2)(128.2))
                1m 39.76s: info: set output video frame_rate(30000/1001)
                1m 39.92s: Intel GPU acceleration for video encoding enabled
                1m 39.93s: info: h264_encode: encode param profile(1) level(30) bitrate(2394)
                3m 23.81s:
                3m 26.37s:
                ------ begin mobile work(2/2) ------
                3m 26.37s: info: create config(0)
                3m 26.37s: info: convert profile(iphone - 480)
                3m 26.37s: info: dvd playlist(1),angle(0),chapter(1->5),3D(0)
                3m 26.37s: info: streams((480.2)(128.2))
                3m 26.56s: info: set output video frame_rate(30000/1001)
                3m 26.64s: Intel GPU acceleration for video encoding enabled
                3m 26.64s: info: h264_encode: encode param profile(1) level(21) bitrate(613)
                5m 04.43s:
                  That's the relevant section of the log. The actual log goes back four or five years so I don't want to post the whole thing.
                  If you need the whole log, I can create a brand new one and try to rip again. But this looks like it has all the data...
                    bump
