BUG? Incompatible with EVGA GTX 970 ACX 2.0
    I recently purchased a GTX 970 ACX 2.0 4GB EVGA graphics card.
    I installed nvidia drivers 347.52.
    Every time I attempted to run DVDFab 9.1.8.8 it would crash programs, then 10 seconds later the system would suffer a BSOD.
    I couldn't uninstall the app because it said the installation files were corrupted.
    I ran SFC /SCANNOW several times, ran a CHKDSK, and ran my OCZ Toolbox to see if the SSD drive was experiencing errors.
    I manually uninstalled it and did a clean install. At the end of the install the system suffered another BSOD.
    I reinstalled Windows from scratch. When I installed DVDFab 9 (which I did after all other programs), it caused another BSOD.
    I reinstalled the GTX 660 Ti I previously had installed, reinstalled Windows from scratch again, then all programs and finally DVDFab 9.1.8.8. No problems. It works.
    Put the GTX 970 back in, reinstalled Windows from Scratch and then all programs and finally DVDFab 9.1.8.8, and BSOD yet again.
    There is no minidump file I can attach and there is nothing in the event log that I can see.
    Is this a bug or something I've done?
    Is there a fix or work around if it is a bug, without having to put my old card back?
    thanks
    Tanya
    NVIDIA System Information report created on: 03/09/2015 11:48:24
    System name: TANYA-PC
    [Display]
    Operating System: Windows 7 Ultimate, 64-bit (Service Pack 1)
    DirectX version: 11.0
    GPU processor: GeForce GTX 970
    Driver version: 347.52
    Direct3D API version: 11
    Direct3D feature level: 11_1
    CUDA Cores: 1664
    Core clock: 1164 MHz
    Memory data rate: 7010 MHz
    Memory interface: 256-bit
    Memory bandwidth: 224.32 GB/s
    Total available graphics memory: 20198 MB
    Dedicated video memory: 4096 MB GDDR5
    System video memory: 0 MB
    Shared system memory: 16102 MB
    Video BIOS version: 84.04.2F.00.70
    IRQ: 16
    Bus: PCI Express x16 Gen3
    Device Id: 10DE 13C2 29743842
    Part Number: G401 0010
    [Components]
    nvui.dll 8.17.13.4752 NVIDIA User Experience Driver Component
    nvxdsync.exe 8.17.13.4752 NVIDIA User Experience Driver Component
    nvxdplcy.dll 8.17.13.4752 NVIDIA User Experience Driver Component
    nvxdbat.dll 8.17.13.4752 NVIDIA User Experience Driver Component
    nvxdapix.dll 8.17.13.4752 NVIDIA User Experience Driver Component
    NVCPL.DLL 8.17.13.4752 NVIDIA User Experience Driver Component
    nvCplUIR.dll 8.1.760.0 NVIDIA Control Panel
    nvCplUI.exe 8.1.760.0 NVIDIA Control Panel
    nvWSSR.dll 6.14.13.4752 NVIDIA Workstation Server
    nvWSS.dll 6.14.13.4752 NVIDIA Workstation Server
    nvViTvSR.dll 6.14.13.4752 NVIDIA Video Server
    nvViTvS.dll 6.14.13.4752 NVIDIA Video Server
    nvDispSR.dll 6.14.13.4752 NVIDIA Display Server
    NVMCTRAY.DLL 8.17.13.4752 NVIDIA Media Center Library
    nvDispS.dll 6.14.13.4752 NVIDIA Display Server
    PhysX 09.14.0702 NVIDIA PhysX
    NVCUDA.DLL 8.17.13.4752 NVIDIA CUDA 7.0.23 driver
    nvGameSR.dll 6.14.13.4752 NVIDIA 3D Settings Server
    nvGameS.dll 6.14.13.4752 NVIDIA 3D Settings Server
    Hi, Yanta
    Please paste your log file here.
    C:\Users\user name\Documents\DVDFab9\Log
    Thank you for your feedback!
      Originally posted by lixichen View Post
      Hi, Yanta
      Terribly sorry, There is NO Log!
      Just to clarify - I upgraded my video card. When I attempted to run DVDFab is caused a BSOD. I couldn't uninstall it because it said installation files corrupted. So I manually did uninstall. Now I CANNOT re install the product without causing BSOD.
      It tries to install software, and then blue screens the computer. I've checked there are NO logs, NO mini dumps, NOTHING in event log and not a single DVDFab registry entry.
      With all due respect, I did specify this in my original post and I would have posted a log if one was available.
      I have also run a Memtest - No problems.
      The BSOD Stop code (BCCode) is 0x00000050 - which is commonly related to video issues.
