DVD FAB Blank media question
    What does everyone use for dvd media ? I have used every thing from sony to memorex you know the stuff you can get at walmart and i have alot of disk sitting around that i cant get to work. Any info will be great
    Verbatim and Taiyo Yuden are the most consistently recommended SL (dvd5) blank media.
    Verbs are available at many brick & mortar stores and online retailers.
    TY media is only available online for most of the planet.
    For DL (dvd9) media it's hands down Verbatim DVD +R DL (preferably made in Singapore).
    TY does not manufacture DL media.
      I only use DVD-R verbatim's also never had a problem. Here is a good deal on DVD-R
      Also check your DVD player manual to see what kind of media it will play DVD-R or DVD+R.
        Thanks for all the info great help ill let you know if this fixes my problem
