Sorry, The current disc is protected by AACS
    When I search the forums, no results are found, even if I limit my search to "AACS". When I google search, I get lots of forum entries, all of them have links that seem to describe my problem, but they all take me to the same page, FAQ main page (indicating they may have been removed?).
    So, i apologize if this is old news or already heavily covered, but I can't seem to find the solution. I saw reference to older versions of DVDFab9 working, but I can't seem to find the older versions to download.
    I have a version of 8 that tried reading the disc for about 45 minutes and then crashed. I had to manually copy the folder from the disc to even get that far.
    Thank you for any help.
    make sure that you are using the latest version of dvdfab and
    it has internet access for the bluray decryption. also please post
    the dvdfab internal log files.
      Thank you for your response. Before I post the logs, I wanted to verify on the version. When I received the error first, I was running an older version of 9. I then ran the updater this morning and am now running 9.2.0.1. When I run the updater now, it says that I am running the latest version (9.2.0.1). I see on the website that 9.2.0.8 (and a few other releases are available). Is it normal that the updater doesn't see those?
      I'll grab the logs from 9.2.0.1 and then update manually from the web and get those as well.
      After seeing another post, I thought I should also mention that the Bluray ripper/copier is activated both on the client and on my account with DVDFab.
      Thanks for your response and for anyone else that can assist.
        you may need to to a complete uninstall of dvdfab and run a registry cleaner
        restart your computer and then try to the latest version of dvdfab.
          9.2.0.1 logs
          Code:
          0m 00.05s:
          DVDFab 9.2.0.1 (2015/08/08  13:16:37)
           0m 00.06s: Init Public log : enabled.
           0m 00.06s: Init Private log : finish.
           0m 00.07s: App info: 2015-5-20
           0m 00.07s: App info: 9.2.0.1 9201 Official
           0m 00.08s: Init CrashReportSettings : enabled.
           0m 00.08s: Init DVDInfo_Log : enabled.
           0m 00.08s: Init Qt_Log : disabled.
           0m 00.15s: Profile Manager :: Begin Load Profile
           0m 00.16s: Qt Translator file load success
           0m 00.16s: App info: client type 10.
           0m 00.18s: MobilePlay load: preload successful.
           0m 00.26s: MobilePlay load: Load successful.
           0m 00.26s: Init process: Transfer settings successful.
           0m 00.27s: info: check logpath= C:/Users/UserName/Documents/DVDFab9/Log/
           0m 00.27s: info: _check_gpu is running ...
           0m 00.49s: info: check_gpu run successful
           0m 00.50s: info: recommand= 8248, Shrink support= 1, enable= 1, cuda_cap= 1 , cpu_count= 12
           0m 00.50s: GPU check: GPUAccelerate-12351
           0m 00.50s: GPU check: GPUAccelerate setting-8248, 8248
           0m 00.50s: GPU check: CUDA cap-1
           0m 00.50s: GPU check: Support coreavc decode-0
           0m 00.50s: GPU check: Lighting shrink status-1, 1
           0m 00.51s: GPU check: Graphics info 1: NVIDIA GeForce GTX 590 : 8.17.12.8579 : 2.0
           0m 00.51s: GPU check: Graphics info 2: NVIDIA GeForce GTX 590 : 8.17.12.8579 : 2.0
           0m 00.51s: Init process: Load config successful.
           0m 00.52s: Init process: Windows os type is 64bit System Windows 7.
           0m 00.52s: Init process: command line in is
           0m 00.57s: Reg check: Parse string: ( 2:8260762964 )( 11:8260762964 )( 20:8260762964 )( 50:8260762964 )( 80:8260762964 )( 21:8260762964 )( 22:8260762964 )( 60:8260762964 )( OV:9201 )( BV:9197 )( S:ac81d73424ecba351b77e8acabcd2876 )
           0m 00.57s: Reg check: Option check status-Local
           0m 00.57s: Reg check: ( HD Decrypter:1:0 )-( DVD to DVD (Gold):1:0 )-( DVD to DVD:1:1 )-( DVD to Mobile:1:1 )-( Blu-ray to Blu-ray:1:1 )-( Blu-ray to Mobile:1:1 )-( File to Mobile:1:1 )-( Blu-ray to DVD:1:1 )-( DVD to Blu-ray:1:0 )-( File to DVD:1:0 )-( File to Blu-ray:1:0 )-( File Mover:1:1 )-( Blu-ray to 3D:1:1 )-( 2D to 3D:1:0 )-( Blu-ray Decrypt:1:0 )-( DVD Decrypt:1:0 )-
           0m 00.57s: App info: language type ENU.
           0m 00.58s: App info: Install path C:/Program Files (x86)/DVDFab 9 US/
           0m 00.58s: Reg check: Start get sys number.
           0m 00.58s: Export Blu-ray source information report : enabled
           0m 00.58s: Reg check: Serial number is: 00-26-83-2f-29-71:54-04-a6-40-76-b9
           0m 00.58s: Init process: Init GPU settings successful.
           0m 00.58s: Reg check: Connect type is: 0
           0m 00.59s: connect plugin info : start.
           0m 00.91s: Profile Manager :: End Load Profile
           0m 01.23s: connect plugin info : 1:1
           0m 01.36s: Reg check: Times of connecting error is: 0
           0m 01.36s: Reg check: Parse string: ( S:aeafcc0c9c2f3a631f7b7cfab96e9070
           0m 01.37s: Reg check: Option check status-NewWork
           0m 01.66s: Init preview: Begin init preview play engine.
           0m 01.66s: Init preview: Begin init preview play engine(Internal).
           0m 02.56s: Init preview: Init internal engine successful.
           0m 03.08s: Burn engine: start init.
           0m 03.08s: Burn engine: set log folder.
           0m 03.09s: DVD: init read settings.
           0m 03.09s: DVD: init write settings.
           0m 03.09s: DVD: DVDInfo_SetDvdrBlocks size = 2201600
           0m 03.10s: DVD: after DVDInfo_SetDvdrBlocks
           0m 03.18s: DVD: after SetBurnEngine, Burn Type = 0
           0m 03.19s: DVD: after init write settings.
           0m 03.19s: DVD: finish init write settings.
           0m 03.19s: BD: init read settings.
           0m 03.20s: BD: init write settings.
           0m 03.20s: bd set region A
           0m 03.20s: Burn engine: config engine type-0 begin.
           0m 03.21s: Burn engine: config engine type-0 end.
           0m 03.21s: Burn engine: writer count 1.
           0m 03.21s: Burn engine: 0- F:\ [HL-DT-ST BD-RE  BH12LS38 1.00 (Scsi)].
           0m 03.22s: Burn engine: end init.
           0m 03.68s: Init process: Init setting page successful.
           0m 03.69s: QtLog Mode = false
           0m 03.70s: Show UI Step 2
           0m 04.00s: Show UI Step 3
           0m 04.00s: Start show MainUI.
           0m 04.00s: UI manager: switch to Converter mode.
           0m 05.10s: allow_test : false
           0m 05.15s: Init process: init main ui successful.
           0m 05.49s: Plugin Info : 1 exits flag = true plugin path = C:/Program Files (x86)/DVDFab 9 US/Plugins\VideoDownload.xml
           0m 05.53s: Init process: show main ui successful.
           0m 05.53s: DriveX msg: Init driveX F with I/O mode: 0
           0m 05.55s: opening drive F
           0m 05.55s: opened i/o
           0m 05.56s: DriveX msg: media open(false) failed in driveX F.
           0m 10.81s: opening drive F
           0m 10.82s: opened i/o
           0m 10.82s: Source manager:open source flag:1,1,1,1,1
           1m 32.74s: UI manager: switch to Convert mode.
           1m 35.24s: UI manager: switch to Converter mode.
           1m 44.91s: set folder F:/BDMV/ with type 2
           1m 44.92s: opening folder F:/BDMV/
           1m 44.94s: set folder F:/BDMV/ with type 2
           1m 44.94s: opening folder F:/BDMV/
           1m 44.95s: Source manager: add source id 0.
           1m 44.98s: bd set region ?
           1m 44.98s: Source open status:DVD Yes, 2231-10-11
           1m 44.99s: Source open status:BD Yes, 2231-10-11
           1m 44.99s: bd set region ?
           1m 45.00s: failed to open 4
           1m 48.29s: Source manager: open failed, delete source id 0.
           1m 48.42s: Source manager: select video files for open.
           1m 48.43s: Source manager:open source flag:1,1,1,1,1
           1m 51.11s: Exit process: stop running.
           1m 51.12s: Exit process: preview pfn_releaseplayer end
           1m 51.17s: Exit process: preview pfn_deinit end
           1m 51.18s: Exit process: preview FreeLibrary end
           1m 51.18s: Exit process: finish MainUI.
           1m 51.26s: Exit process: finish FreePref.
           1m 51.26s: Exit process: finish AVEditWrap Release.
            The current version for Windows is 9.2.0.8 get it here: http://forum.dvdfab.cn/showthread.php?t=27591
              Thank you. Uninstalling, removing all orphaned registry entries and then installing from scratch resolved the issue.
