I am running Windows 7 SP1 64bit OS successfully with DVDFAB v 9.2.4.4 (and all previous v9x versions), however when I upgraded to DVDFAB 9.3.3.0 Beta today, the DVDFAB app crashed. I have an older i7 motherboard (ASUS P8Z68 Deluxe) that requires the Lucidlogix Vitru app (v1.2.112) to make DVDFAB aware that I have a system that can take advantage of the Intel Quick Sync transcoding engine. In other words, I can use Lightning-Shrink for H264 and MPEG2 Codecs when Virtu is active.
My current workaround is to 1) Turn off the Vitru app and then 2) Run all my DVDFAB Video decoders in SOFTWARE mode. Clearly this is not optimal, since my CPU runs at 100% and my frame conversion rate drops by 60% - taking longer to decode.
Making matters harder, there does not seem to be any log created by the DVDFAB app when this happens. I get your app splash screen, then it terminates.
So what more, documentation wise, can I present to you to help troubleshoot this problem? I know this cliché has been over stated, but I made no OS and or application changes between successfully running DVDFAB v9.2.4.4 and then installing your Beta v 9.3.3.0 -which has crashed from the first install.
Regards,
Ken
Regards,
Ken
