looking on info for BD 50 gig media, where and how much?? Thanks riz
Where is A good place to get BD-R50 media, without breaking the bank??
I haven't found any Blu Ray DL 50 Gb media yet that doesn't break the bank. My bank breaks at $5/disc. However, mediamegamall has good prices on 25 Gb 4x speed verbatim (< $3) although I think their shipping costs are a little out of line. Let us know if you find some reasonable 50 Gb DL made by a reliable manufacturer.
It's too expensive right now. I'd suggest writing your stuff to the hard drive and then playing it back from there as well.
If you must buy BD-50 media the best prices are from Japan on Ebay for about $10 for a BD R 50 and $15 for BD RE 50 in quantity.
Also check out: http://www.shop4tech.com/z/Blu_ray_BD_R_Media/1_440/
Originally posted by McLovin View Posthttp://www.newegg.com/Product/Produc...82E16817501029
Memorex 25GB 4X BD-R 15 Packs Spindle Disc Model 97854 for $24.99 free shipping. That's $1.67 per disk.
.AX
The default Log File location: C:\Documents and Settings\"User Acct"\My Documents\DVDFab\Log
I go to Ebay to get my BD-R 50GB disks. There are a couple of sellers, JP-Gift and JP-Stop from Japan that will sell you packs of 3, 5, or 10 without the cases. These are Mitsubishi/Verbatim and right now the best price they have for a 10-pack is $66.50 ($6.65 per disc). They also do 5 packs and 3 packs. I have never had an issue burning these discs. I have an LG WH08LS20 burner.
