Can you select VC1 with Cuda and not get a pop up saying it's not supported as I have intel graphics and can now select hd graphics for h265 but a pop up say not supported with your graphics card for both h265 and VC-1 then goe's back to software for the above two.
P.S. I thought your power cuda card could work with h265 and Fab.
Is it decode and encode with h265 or just one with that new power cuda card?
@90312, you 980 does not support H265 decoder, but support H265 encoder.
Does the windows version matter with the 1060 as I have the free upgrade from windows 7 windows home version 115 OS build 10586,589 and for $199 the 1060 is well worth the money if it will work with windows 10.
It works in Windows 7, 8 and 10. Just download the driver directly from Nvidia. The drivers on the CD's are normally out of date when you get them. I just looked right now and there is a new driver today.
