At least the 980 is not, it is Maxwell. I should add that Maxwell does not disqualify the on chip decoding of h.265 it just isn't on the GTX 980. The GTX960 is Maxwell and it is on chip.
DVDFab 9.3.1.6
 Did i read somewhere on the forum you may have 3d disks now?
 If so i wonder if you dropped to windows 7 from your second boot drive if you could see if the profile 3d MKV side by side 265 can be used to convert a 3d 264 blu ray with cuda for encode and decode when ripping such 3d disk.it's just one or the other now with both quick sync and cuda does the new 960 change this so you get both or is this Fab software dependent also?
 Also their is no using cuda or quick sync when reducing a regular full 3d movie to 25 gigs normally doe's this change with the 960 card or as I believe is this because Fab doesn't support cuda for full 3d in the software program itself?
 If you don't know maybe Wilson can answer this one and will Fab support this in the future with the Power cuda cards such as the 960? Thanks.Last edited by 3dman; 09-21-2016, 09:33 PM.
 Yes apparently you can do h.265 3D SBS:Attached FilesHow to post the internal log
 Cuda and quick sync always worked for Encode for 3d side by sides H264 but not decode seems this is what your log shows also for h265 also.Still 14 mins.not bad at all for 3d conversion to h265.I am really impressed.
 For full 3d to compress to 25 gig their was never cuda support or intel quick sync support so i guess it's Fab software related and i was wondering why not maybe a question for Mr Wang or Mr. Fengtao.Also why no decode support for 3d side by sides seems ideal jobs for the newer power cuda cards.
 Sorry if I misled you I only did a few chapters. Off the disc it was only about 50fps and would have taken a long while.How to post the internal log
 Yes, for now, DVDFab does not support IQS or CUDA in Full 3D compression.For full 3d to compress to 25 gig their was never cuda support or intel quick sync support
 WilsonPlease post your logs the default location is:
 Cuda and quick sync always worked for Encode for 3d side by sides H264 but not decode will fab ever support decode for side by sides?
 Being that there's no Cuda or Quick sync at all for full 3d compression do you mean Fab will support it in the future as we really need it with 3d movies.
 Thanks.
