Write to disk speed
    Originally posted by jetman4615 View Post
    Thanks for reminding me. I just finished the firmware upgrade. Can you expand on your explanation regarding riplock. I am not familiar with it.
    Thanks
    See here - https://en.m.wikipedia.org/wiki/Riplock
      Img burn is professional burn software and puts out a very good log file telling every step and all you need to know to fix problems.Here is the link from the super moderator to get Fab to work with img burn if you need this information http://forum.dvdfab.cn/showpost.php?p=55&postcount=2
      Once set up fab will open img burn and burn the disk for you all by itself and a log file will go into the saved log files should anything go wrong you know now how to post and where to look for log fies.Please go ahead and burn a disk and see the results if the same post the new Img burn log file.
        How to increase write speed.
        I really appreciate all your help. My dvd device firmware was upgraded. I switched to ImgBurn, and all my problems disappeared. I just finished burning a copy that took eight minutes at max speed. I was hoping that it played ok and I did flawlessly. Thanks for the links regarding ImgBurn tips. Also to the others that contributed info. Moderator 90312 on creating an iso file. I looked at the burn log and internal log, which shows complete data.
        Again, thanks to all for the support.
