Using Images in Forum Posts
This is a sticky topic.
    Official Guide Using Images in Forum Posts
    Is one really worth 1000 words? In some cases yes, and you can easily add them to posts in the forum to help illustrate a problem or question. Here is a brief Guide:
    General Guidelines
    Choose an image that helps illustrate your topic. The maximum dimensions for the forum are 700x500, so if you will probably need to crop and/or resize the image to meet these requirements. Larger images will be automatically resized by the forum processing software, but they will not look very sharp or clear in your post. For the best results, prepare them beforehand with simple image software such as MS Paint, which comes with Windows. It can crop and resize images and tell you their size:
Name:	1-011 IMAGESGUIDE1.png
    For best results, use png or jpg file types.
    Attaching the Image
    Once the image is prepared and stored on your hard drive, begin typing your new thread or post. Activate the Advanced editor by clicking on the "A" as shown in the capture (1). When you come to the point where you want to display the capture or picture, Click in the Insert Image icon (2) in the editor toolbar, as shown.
Name:	1-011 IMAGESGUIDE 2.png
    This will bring up the image setup box below. Click on the Upload tab (1) and browse to the file you stored earlier (2). When you locate and select it, click on "send it to the Server button.
Name:	1-011 IMAGESGUIDE 3.png
    When the upload finished, the box will automatically switch to the Image Info tab shown below. All you need to do here is select the positioning and Link type and click OK.
    The image should now appear in your post.
    Key things to remember for good images:
    • keep the size at 700x500 or below
    • do not use ultra-high quality jpgs
    • do not use bmp files at all
    Please also remember that not all members have reliable high speed internet service, and images can slow down page loads for them tremendously. Use images only when they are required to illuminate the problem or question that is the subject of your post/thread.
    The images in this guide were cropped from 1920x1080 desktop captures using MS Paint.
