This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
I'm no expert on drives but I wouldn't say extreme wear. You can use some suggested methods to prevent extra wear and tear on a drive such as ripping full disc to hdd first then (provided a new protection scheme that prevents a correct rip the first time around) test and/or continue working with the rip from the hdd.
Of course some drives are more apt to failure than others (namely slimtypes in laptops). Also the most wear and tear comes from the burn process.
Again I'm no expert on optical drives and maybe someone has a better answer.
Insofar as drive itself, there's no difference between playing or ripping.
I'm not sure what the actual, average number of plays/rips is in the lifetime of a drive, BR or otherwise.
I've done tons of rips and I've also retired a number of burners.
I have yet to have one actually die.
Not to be a smarta$$, but it's just doing what the drive is designed to do. Kinda like a vacuum cleaner vacuuming...how many times will it vacuum?...lol.
It's best to rip an image to the hdd and if you have other tasks to do like converting,
use the hdd image and it'll cut down on the wear and tear of the ODD.
It'll be a lot faster too
If I may I would like to add that external burners are great. As long as you use them for just that. I burnt out my last one using the light scribe which just kills the life of the laser. I know better this time.
Yeah, I looked around and folks are tallkng 45 minutes to rip and 13 hours to compress.
Thanks GregiBoy.
I'll go back and edit my post, so I don't lead anyone astray.
One thing that I have noticed...Example...I backed up Star Trek BD using a Lite On iHES208. It rips at 4X, but with compression...rip speed and compression took 1 hour and 40 min...then the Pioneer was loaded and ready to go.
Compression also depends alot on the processor and rig you have. Even when I dub home movies to DVD...with my i7 processor...the recoding of the movie used to take a 1:1 (so a two hour movie took two hours to dub and two hours to encode to DVD). Now...with the i7....and two WD VelociRaptors in RAID 0///two hours to copy...and about a half hour to re-encode. Makes a big difference.
So the gist is to have one BD reader and then just burn with the Pioneer BD-205. That is my intention at this point...but the Lite On is not a good candidate...for it is soooo sloooow! Waiting for the new LG CH10LS20 BD reader / DVD Combo drive to come out. According to LG...will rip at 8X. BTW...so does the Pioneer...but I am trying NOT to rip/ compress and burn all at the same time...
