A large number of the titles in my online library are from disks I got while living in Russia. Thus, the default language is Russian. I should have changed them when I Fabed them by moving the blue arrow on the interface, but I didn't and now I have a number of titles that I have to switch the language on each time I use them. One by one I have updated several, but if there is a way to do it with a batch script I would like to do so. So, if the default language is set to "Russian" I would like to change the default to "English", but only if that condition is met.Perhaps "signals" will chime in again with another astute suggestion.
Changing Default Language
Originally posted by MotoMorgan View PostA large number of the titles in my online library are from disks I got while living in Russia. Thus, the default language is Russian. I should have changed them when I Fabed them by moving the blue arrow on the interface, but I didn't and now I have a number of titles that I have to switch the language on each time I use them. One by one I have updated several, but if there is a way to do it with a batch script I would like to do so. So, if the default language is set to "Russian" I would like to change the default to "English", but only if that condition is met.Perhaps "signals" will chime in again with another astute suggestion.
at the preferred language setting ??
