background processes
    just noticed that the following are running in the background (win-10)
    dvdfab player 6 (32 bit), and
    dvdfab player server (32 bit)
    can someone explain why they are running in the background?
    thanks....
Name:	Player auto start.png
    Player could be running in the background, please check the Settings section first, see the image above.
      I too have noticed DVDFab Player Server.exe *32 shows individual entries in Windows Task Manager for every video I've played. DVDFab Media Player 6 is unchecked as shown in your picture above, and is unchecked in Windows "msconfig - startup" as well. Yet when I use Media Player 6, it stays in Task Manager as well as the server entries for every video as well. How do I get Media Player 6 to only start up when I want it to, and then completely shut down when I'm through with it? I either have to restart the computer each time I use Media Player 6 or stop each process in Task Manager individually. I don't like arbitrary things thinking they can run in the background all the time. I look forward to your reply. Thank you!
        I figured out the Task Manager problem. On the DVDFab Media Player 6 settings, there is an option called "Minimize to (systry) when closing the main window". With this one UNCHECKED, it does indeed shut down all entries in Task Manager. I hope this can help the original poster out. Thanks!
          Thanks for sharing.
