This Notice is to alert you that the Spring Festival (Chinese New Year) Holiday is underway in China and much of Asia and for this reason the DVDFab Office will be closed until February 4. During this period, support by chat and email will not be available but the forum will be here for any problems you may encounter. Purchases of new products and license renewals may be made normally on the DVDFab website. Thanks for your understanding and Happy New Year!
I am trying to stream a blueray movie. However my popcorn hour A-110 nor will my E-Great M34-A play a blue ray file. I am told that I can remux to a
m2ts file. How\What do can dvdfab do this?
A Blu Ray movie is m2ts. When you say stream what do you mean? I currently stream full quality Blu Ray Movie files over my home network (needs to be Gigabit Ethernet at least) to Windows Media center from a Media server. You need a movie player that works as a plug in to media center because media center (for windows 7) does not natively support the m2ts file format. It recognizes it as a movie but will not play it without another player.
I am streaming gb from my server to 100mbps to two network media tanks.
Popcorn A-110 and E-Great M34A.
I posted in the NMT forum and theys said:
"You would have to rip it and use a different container to play on it."
Here is the media info dump on the file. I think they mean change the codec off of VC1. or perhaps I am misreading what they are stating. If it is change the codec can DVD fab make that change... if so how?
F:\yamj\mediaInfo>mediainfo --Full i:\mv2\book4\the_XXXXX.iso
General
Count : 259
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Count of video streams : 1
Video_Format_List : VC-1
Video_Format_WithHint_List : VC-1
Codecs Video : VC-1
Complete name : i:\mv2\book4\THE_XXXX.iso
Folder name : i:\mv2\book4
File name : THE_XXXX
File extension : iso
Format : VC-1
Format : VC-1
Format/Extensions usually used : vc1
Codec : VC-1
Codec : VC-1
Codec/Extensions usually used : vc1
File size : 34177482752
File size : 31.8 GiB
File size : 32 GiB
File size : 32 GiB
File size : 31.83 GiB
File creation date : UTC 2010-03-20 20:39:30.390
File creation date (local) : 2010-03-20 15:39:30.390
File last modification date : UTC 2010-03-20 21:18:04.265
File last modification date (loc : 2010-03-20 16:18:04.265
Video
Count : 146
Kind of stream : Video
Format : VC-1
Format profile : AP@L3
Codec : VC-1
Codec : VC-1
Codec/Family : VC-1
Codec/Url : http://www.microsoft.com/windows/windowsmedia
/format/codecdownload.aspx
Codec profile : AP@L3
Width : 1920
Width : 1 920 pixels
Height : 1080
Height : 1 080 pixels
Pixel aspect ratio : 1.000
Display aspect ratio : 1.778
Display aspect ratio : 16:9
Frame rate : 23.976
Frame rate : 23.976 fps
Colorimetry : 4:2:0
Scan type : Progressive
Interlacement : PPF
Interlacement : Progressive
DVDFab Blu-Ray to Mobile module will work using MKV remux. Make sure to click the checkbox that removes HD audio (if available). However, even after removing HD audio, many if not most BD titles will be in DTS. You will need to check the NMT forums to see what is required to play DTS via the PCH.
You do not need to change containers. I stream the raw rip of the blu ray from my media server.
Items needed to stream raw Blu Ray rips
1) From server to client machine the network needs to be Gigabit to stream blu ray movies. The TCP over head plus the bit stream just barely exceeds the 100mbs bandwidth. Granted 100mbs will stream the smaller blu rays (ones that are less than 20gigbytes in size but any moves larger than that it will studder)
2) A plug in player for media center (like Arcsoft Total Media Center 3 Extreme will stream the m2ts files without a disk check over the network). That is also the top rated software blu ray player on the market as well. This will decode all the HD Audio codecs out there as well. Playing the raw blu ray movies will maintain your 5.1 - 7.1 audio as well ( putting the movie into an container you will loose the surround sound, it mixes the audio down to a 2 channel source and you also get studdering your movie putting then in a container if your are trying to maintain the 1080p quality. From New Egg the software player costs about $56.00 and from the vendors website about $99.00.
I am doing this on as follows:
Server Specs:
Dual core 2.66
2gs Ram
Netgear Gigabit Ethernet card ($50.00)
8TB Hard Drive space
Client Machine:
Athon x2 1.86
2gig ram
Netgear Gigabit Ethernet Card
ATI 4550 Video Card (intergrated video cards will not work because of the processing power needed to process the 1080p video source, even if the cards states it is an HD card, the shared resources of the CPU and Ram causes the video to skip)
The client machine can be a basic computer the important part is the video card and network card. I know that the Netgear card and ATI card i stated works flawlessly. and the cost it minimal for what is trying to be accomplished.
(Total cost of the client machine $350.00)
Switches
Netgear Gigabit Switch ($50.00) (Linksys does not make a Gigabit Switch that handles Gigabit network traffic withing a reasonable price range)
This solution had worked flawlessly for me for several months now. I tried the whole encoding of the m2ts video into meg4 and I had no luck because of the support of the HD Audio Codes are not there and not all movies have non HD Audio tracks.
I do finally have this working, and no I was not working on it all this time.
What I do is rip the BD main movie the the hard drive.
Then I used the DVDFAB Blue Ray Ripper option and send it to and MKV format. In the profile drop down I choose the remux option wait few hours for it to finish and everything works... However trying this in a one step from B-DVD to MKV with remux I have not had much sucess, so for now it remains two steps.
