Update or upgrade
    Update or upgrade
    I paid for a DVD version back in February how do I make sure I have the latest version right now I have 6.2.1.8. I'm trying to back up new moon.
    Bigdaddy
    The newest beta to burn new moon is here
      Do I treat this like a new install? I'm new to this sorry for the dumb questions and thank you for your help.
        it will install in it own directory as it is DVDFab 7 but you can use your DVDFab 6 key to activate it
          Bigdaddy
          Yes just install as usual it will install in a separate folder and if you want to keep 6.2.1.8 you can, or you can delete it, I usually keep more than 1 version of Fab on my computer.
          Also after install right click and run as administrator and you will be all set>
            Trying it right now. Looks like it's going to work. Thank you very much for your help!!
              Bigdaddy
              Your welcome glad I could help.
