When you purchase DVD Fab, does the license allow for installation on 2 separate computers, or is a license only good for one computer?
License Key
J1s15n
Yes you can install it on 2 computers, BUT you can only run Fab on one computer at a time as your license key may get blacklisted.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
J1s15n
As far as I know the answer is yes, but I may be wrong, maybe a moderator could be more helpful in answering that question.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Originally posted by J1s15n View PostThats weird, so I must have an internet connection to use DVD Fab now?
You don't need an internet connection to run it; much like windoz and any other number of programsIf it ain't broke, don't fix it!
Ok, well I love DVD Fab, so I think I'll buy the new version. We only have 2 computers, so it's important that both of them have it. Since I'm in the military, it will be good to have on both computers because I take mine overseas with me.
The fact that you don't need an internet connection is not needed is great because of the lack of internet in war zones.
Thanks to all who helped!
Originally posted by reg410 View PostI noticed you said you can install Fab on 2 computers but only run it on 1 at a time, I used it for work project both at work and home, so I have to buy a second download to use it on both?
You must agree to only use Fab on one pc at a time.
As described, you run the risk of being blacklisted (tagged as pirated software) if one license is "seen" running simultaneously on multiple pcs.If it ain't broke, don't fix it!
