I don’t know that OS, but it might be of a vintage that doesn’t have all the C++ run time components. Microsoft has a C++ redistributable package available for free download that improves your ability to run C++ developed software if it doesn't. Even if it doesn’t fix your problem it won’t hurt a thing to install it. Google it.
Welcome to dvd fab
Originally posted by 90312 View PostI don’t know that OS, but it might be of a vintage that doesn’t have all the C++ run time components. Microsoft has a C++ redistributable package available for free download that improves your ability to run C++ developed software if it doesn't. Even if it doesn’t fix your problem it won’t hurt a thing to install it. Google it.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
Originally posted by 90312 View PostI don’t know that OS, but it might be of a vintage that doesn’t have all the C++ run time components. Microsoft has a C++ redistributable package available for free download that improves your ability to run C++ developed software if it doesn't. Even if it doesn’t fix your problem it won’t hurt a thing to install it. Google it.Originally posted by CBR929 View PostVery good advice as I see many users that are running old service packs that may be missing updates for programs to run correctly.
Version 7.0.3.0 runs fine on Windows 2000 (just had to install GDI+ redistributable, but it's not required for XP).
I don’t know for sure it will fix the OP’s problem, but like I said it won’t hurt to have the latest libraries always centrally available to the executable.How to post the internal log
witchrayc
Glad to hear your up and running now GET BURNINGEven if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
I'm back.
Ok, back from the beach, browner and calmer.And yes, 90312, a balmy 24C.
Just to re-iterate, I'm running XP Home Version 2002 Service Pack 3. I already have SP3 WitchRayc.
This is what I did:
a: Checked in my Programs list that I had all the latest .net frameworks installed, together with the Microsoft 2008 C++ redistribution pack. I checked in the list under "Add and Remove software" because I got some error messages when I installed them. Apparently Microsoft are aware of this happening and say that the error messages can usually be ignored. That was the case with me.
b: I downloaded the latest beta version of the DvdFab software from the link provided in the forum and saved it to hard disc.
c: I switched off my Trend Micro personal firewall.
d: I ran the exe file as administrator and unchecked the "Protect my computer from nasty viruses" box.
e: The software installed and a drop down menu offered to change the DMA settings to get the software to run better. (I had looked at those before but never mind, I said yes, change away.)
f: I switched my firewall back on. Not sure if that was a factor but just thought I might as well try it. Dvd Fab is now added as trusted software within the Trend Micro list. That way when it looks for the latest update I shouldn't get any "Block this?" queries.
I now have the trial version 7 up and running and have a generous month to try it out before I buy. YIPPEE.I still get the welcome screen of course, but now when I hit "Start Dvd Fab" after about 10-15 seconds it actually does so.
Thanks everyone for sticking by me. This package is amazing.
DizLast edited by Dizzy; 04-12-2010, 07:53 AM. Reason: adding about the welcome screen just for clarity.
Dizzy
Glad to hear you got it working and welcome to Fab.Even if it's a little thing, do something for those who have need of help, something for which you get no pay but the privilege of doing it.
