I've been using dvdfab 7 on my old windows laptop, but recently put bootcamp on my new macbook pro so I could migrate to my mac completely.
My problem is that when I try and rip a dvd to the hd it never fully recognizes the dvd. It will pull up the progress bar that pops up when you put in a DVD but instead of cycling through the full length of the bar 4-5 times like it did on my old windows machine, it cycles through once and then goes away. But after the progress bar disappears all the information boxes are still blank, like they would be if no DVD was in the laptop at all.
Has anyone run into this problem, or similar ones with macs and bootcamp?
