Deleted Old Versions
    I had origianlly purchased dvd fab platinum 4 and then updating to version, 5, 6 and now the new 7 with all the other versions still installed on pc. Used the 7 and worked great so decided to delete all the other versions. Now, when I use version 7 it is coming up ( you are going to try dvd to dvd), giving me the impression I am running on a trial here. Saved my original 4 on disc but can not install....how can I fix this.
    Have you re-entered your key?
      If all else fails refer to this guide.
        I have not been given that option
          What OS are you running on your machine?
          sigpic
            As a test since I have V4 V5 V6 and V7 on my pc I deleted all but V7 and it still works and shows as registered.
            Have you tried deleting V7 and re-installing?
            Make sure you have saved your key in a safe place.
              I am running xp
                I will try that. any reason you have kept all versions on your pc?
                  All of us old heads keep the previous versions so that on the odd ocassion when a idiosyncracy pops up, we can check with a previous version.
                  Also, on some ocassions, the older versions handle older titles better.
                    All you need to do is double click on your registration key that you have for V6 and then reboot computer. After reboot it should be activated with lifetime like it should be
                      Exactly, someone's been reading my thoughts again...or vice versa...
                      All major versions, ie., Fab 2, 4, 4, 5, 6 & 7 are installed in different folders are are indepenent of one another.
                      As far as storage, given the fact that most of us have multiple 1 TB or > hdds, archiving 5-12 MB installers is not a problem...
                      And for the average user, generally a few selected older versions will do the trick.
                        all is well now but how do i reload the older versions (which i saved on disc), tried but no set up or exe file.
                          You need the installers...like any program.
                          How and what exactly did you save?
