Registration for "DVD to Mobile" option
    My registration is valid for the "DVD to DVD" option and the "DVD to Mobile" option. This is verified by the e-mail I received to reregister my DVDFab7 software:
    Thank you for choosing DVDFab!
    DVDFab "DVD to DVD" (Never Expire)
    DVDFab "DVD to Mobile" (Never Expire)
    But when I enter the registration information and check my registered options, the "DVD to Mobile" option says:
    Option - DVD to Mobile
    Licensee - Trial User
    Enabled - Yes
    Update Expire Time - May 17, 2010
    I have reregistered using both method 1 and method 2 many times. Each time the "DVD to Mobile" option is set to expire, instead of "never expire".
    What am I doing wrong? How can I get DVDFab7 registered properly so that I can use the "DVD to Mobile" option after May 17, 2010?
    Thanks for your help.
    RG
    Take a look at this help thread .
      It worked!!
      Hey, thanks.
      I tried the method described in that help thread, and it WORKED!!
      I now have a "never expire" license for DVD-to-Mobile.
      This is a great forum.
      RG
