Nero question
    Nero question
    MAINEMAN, sorry to but in, you said that there is no capatible nero version for Win 7 64-bit, I have nero and going to get a new computer with Win 7 64-bit, should I renew with nero or do you have a sugguestion!:
    Nope, you misunderstood.
    I said I don't have a compatible version of nero to run with Win 7. I do have assorted nero 6.xxx apps which will run just fine on XP.
    I haven't been particularly enamored with later versions of nero and frankly, I don't need it.
    I'm not about to shell out substantial $ for what essentially would be a downgrade, not an upgrade .
      I have Nero 8 installed on Windows 7 and it works good even if Nero tells us on the homepage that only version 9 and later version are compatible with Windows 7.
        capatible version
        Thanks MAINEMAN, I felt the same as far as the price and as a down grade! thank you to Gummigutta, I'll just keep old nero! thanks guys!!
