bits per pixel?
    bits per pixel?
    whats the average we wanna strive for?
    whats the lowest level which gives acceptable quality?
    This is a result of bitrate (kbps) and frame resolution. I find anything above 0.2xx gives acceptable color depth, more is better but there is a file size consideration. I think if you keep it above 0.2 you'll like it on a hand held device.
      How much do you need to get clean pristine conversions of ole B&W classics
      1. to kill a mockingbird
      2. casablanca
      3. citizen kane etc?
        2. casablanca
        Clean pristine means same as original.
        sigpic
          ya ya
          same same
            I keep my B&W bit depth about the same as color ollie. It keeps the black from fading to gray and the demarcation lines between those two colors crisp.
