Creating ISO files question (.ini files)
    When i first started creating ISO files they were created in a folder named after the movie:
    My Documents\DVDFab\ISO\YES_MAN\YES_MAN.ISO
    the folder contained 2 files; an ISO file, plus another file with an .ini file extension
    now the ISO files are created in the main directory (not a folder named after the movie) and there is no .ini file:
    My Documents\DVDFab\ISO\YES_MAN.iso
    why is this happening, is the .ini file important?
    Thank you very much for your help.
    This sounds like you have turned off the "Create files in subfolders of the output directory" in "General" settiings.
    It's really up to you how you want to structure the directories.
    The INI file is most probably something created by Windoze and is nothing to do with the ISO.
      Agreed.
      As far as the .ini file...
      this is created by Fab when using clone mode and contains the layer break info.
      This occurs with VSO and Img when utililzed within Fab.
      (If you were to create an .ISO in build mode with Img as a standalone, Img will create an .MDS file for the layer break info).
      If you select a mode other than clone...say customize ---> .ISO, the .ini file will not be created on DL rips.
